Hello Sir.
A condition like the above can point out many solutions depending on the points which can cause the inconvenience:------
Thank you Sir. If you have any further doubts about my solution, please reply me.
If that is the case , it will be better if you try using a different keyboard so we can see if that new keyabord will be working, because if the other like a usb keyboard will be working so we're sure that its a keyboard problem....
As an IT engineer, I would definately say the keyboard is faulty. A replacement of the keyboard should do the job. This is more a hardware fault than software.
Please do not rate this reply unless I have answered your question or your reply will not be returned to me. Thanks.
If the keyboard is the problem, does it go partially bad where only a couple of numbers and a few character still type?
My keyboard does not type letter when the keys are pressed, a few keys like the number "1" will print out "-23\87", the "A" will print out "\+21d", the P will print "-", most of the letter keys will not print anything.
Already tried a new keyboard for this model MPC and it did not work, so it is not the keyboard! I checked the connection from the keyboard to the mother board and looked good. Could it be the mother board printer section?
