HP PSC 1510 All-In-One InkJet Printer Logo
Posted on Nov 29, 2007
Test Page Problem
My HP PSC 1510 All-In-One InkJet always print test pages whenever it switch on. why?
What is the solution to this problem because I just bought it 2days ago.
thanks.
Bayode Daramola
  • 2 more comments
  • Anonymous Dec 06, 2007
    My HP1510 prints a test page everytime I turn it on. It didn't do this before I changed out the black cartridge. I put it on the scanner and press the scan button exactly like it says to do. The scanner goes across the page and the power light stops blinking like its supposed to.It still prints the page everytime I power it up. I'm not a fan of leaving it on all the time and I've never manually prompted the unit to print the test page. I've reinstalled both cartridges countless times yet the problem still persists.
  • Anonymous Dec 09, 2007
    We have had this printer for about two years or so and we have always had this problem. I would love to find the solution because I am sick of buying the ink cartridges (which aren't cheap and run out way too fast!)
    same problem,,, it prints a test page every time we turn it on! wasteful..
  • dontut Nov 27, 2008
    This problem has driven me crazy from the start of owning this machine. I get the feeling that I am being deliberately ripped off by HP. So much so that this printer is now only a backup to a very cheap lexmark printer so the plan is not working for HP.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 28, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
755
Points
Hey there ppl.
I had the same problem every time i turned on my hp psc 1510 all-in-one. I found the solution to the problem on hp's homepage. Here is the link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01336348&lc=en&dlc=en&cc=us&lang=en&product=428800
its quite easy! but if it does not work the first time i would try again before having it repaired og changing the ink.
good luck to you all
A
Anonymous
I have a hp psc 1350 all-in-one, what the 'guest' suggested does not work at all. what i got is just a waste of several more pages and some inks!
Anonymous
Level 1:
  • Contributor 27 Answers
  • Posted on Dec 13, 2007
Anonymous
Contributor
Level 1:
Answers
27
Questions
Helped
8948
Points
35
I followed the directions posted by "guest" on Dec. 13th as suggested. All this did was waste more ink on test pages. I've scanned pictures to make sure the scan feature still works thinking maybe it isn't alligning the cartridges cause the scanner went bad. The scan feature still works. I believe the only solution for this problem is to simply leave the printer on all the time.
I dismantled my printer to hopefully find a reason for its paper feed problem. It would jam up on the left side as it was printing the page. When I opened it up I found a piece of black wiring lying in the paper path. I removed the wire which wasn't connected to anything and reassembled the printer. It now works fine other than the test page issue. I should note that my printer was a "remanufactured" printer and no longer had a valid warranty.
A
Anonymous
Read this and you will find the solution for all your problems.
Courtney
: Hi Ivan,
Courtney: Welcome to HP Total Care for All-in-One products. My name is Courtney. How may I assist you today?
me: Hello
Courtney: I hope you are doing fine today.
me: I have problem with HP PSC 1500 All-in-One series
Courtney: Could you please provide me with a detailed description of the problem which would help me serve you better?
me: I am having this printer for about two years or so I have always this problem. I would love to find the solution because it prints test page after every swith on I am sick of buying the ink cartridges (which aren't cheap and run out way too fast!)
me: My HP1510 prints a test page everytime I turn it on.
Courtney: Okay.
me: Is there any solution to turn off terst page print after every swith on??
Courtney: Is the printer directly connected to the computer with USB cable ?
me: That is my problem. Please help.
me: Yes, connected with USB directly to the PC
Courtney: Have you replaced the ink cartridges recently?
me: Yes, but he does always print that test page after swith on.
me: Yes, but he does always print that test page after switch on.
Courtney: A;right.
me: What I need to do to turn off that test page print after every switch on?
Courtney: Disconnect the USB cable from the all-in-one.
Courtney: Place the test page face down on the scanner glass and press Scan. The alignment is complete when the On light stops blinking.
me: Just the second.
Courtney: Sure.
me: Yes I done that. What next?
Courtney: Now turn off the printer and turn back on.
me: Yes, I did. It is still disconnected from USB. Next?
Courtney: \
me: What?
Courtney: Please connect the USB cable.
me: ok, just the second
Courtney: Is it printing the test page again?
me: yes, i did connected hp psc with computer via usb. pc is off all this time.
me: just the second.
Courtney: Sure.
Courtney: Let me know the result.
me: I did switch off the printer. Then I did connect printer with USB. Then first I turned on PC and after Windows 98 started and loaded, then I switch on the printer and he did not print test page.
Courtney: Fine.
me: When I need to make again those steps? After each change of ink jet?
Courtney: Sure.
Courtney: I believe the issue is fixed. Am I correct?
me: Yes, thank you very much for all your help.
Courtney: It' my pleasure.
Courtney: Is there anything else that I may assist you with?
Courtney: Good Bye and Take Care.
me: No, that you again for all your help.
me: Have a nice day and coming weekend.
me: Merry Christmas and Happy New 2008 Year.
Courtney: Happy New Year.
Courtney: Thank you for using HP Total Care and giving us an opportunity to serve you through Real-Time Chat. Please contact us again if you require any further assistance. We are available 24hrs a day, 7 days a week.
Our exclusive Owner Services will help keep all of your HP and Compaq products up and running. Please visit our Web site at:
http://www.hp.com/home/ownerservices
Anonymous
Level 1:
Problem Solver:
  • Contributor 19 Answers
  • Posted on Nov 30, 2007
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
19
Questions
0
Helped
5184
Points
23
Well as it seams u have given the order to ur pc to prin a test page before....but it wasnt responting so u keeped pressing the bottom..! so to fix that u can go to contro panel>printers and faxes and there u can find ur printers name...after that duble-click on ur printer and it shows a printer dialog...then delete ALL the documents that is ready to print...after that u r ready to print again!! but always remember that if u "say" to ur printer to print a page and it doesnt respont as soon as posible, it doesnt mean it wont print!! just click ONCE the print bottom the other time :)
dont forget to vote!!
Stratos
Anonymous
Level 1:
Teacher:
An expert who has written 2 tips or uploaded 1 video tip.
  • Contributor 12 Answers
  • Posted on Nov 18, 2008
Anonymous
Contributor
Level 1:
Teacher:
Answers
12
Questions
0
Helped
4420
Points
23
The clue is here:
<excerpt>
</excerpt>
The problem is that each time you replace a printer cartridge the printer wants to reallign itself. You simply need to take the test page and scan it to help the printer do this.
Once done, the problem should resolve itself until the next time you replace a print cartridge.
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
