Konica Minolta bizhub 350 All-In-One Laser Printer Logo
Posted on Aug 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HOW TO SOLVE ERROR CODE COF32 - Konica Minolta bizhub 350 All-In-One Laser Printer
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 29, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1146
Points
Change the dveloper then calibrate
Anonymous
Level 2:
  • Expert 52 Answers
  • Posted on Aug 07, 2009
Anonymous
Expert
Level 2:
Answers
52
Questions
0
Helped
14469
Points
143
This is an ATDC sensor failure, Auto toner density failure, due to the fact that the pages are all black would probably indicate that charge also is dirty?
Without looking at the machine in person, its hard to tell. Good luck
1 Related Answer
xeerie
Zaheer Ahmed
  • 347 Answers
  • Posted on Jun 17, 2010
SOURCE: REMEDY TO SOLVING ERRORS COF32 AND CO650 IN KONICA
to remove code "COF32" from your machine, simply change the developer with the new one. code will remove.
wish you best of luck............
Reset error code cof32 dialta minolta Reset error code cof32 dialta Minolta DI.1611 How to reset erro code cof32
Recommend you replace the drum and developer, after clearing the counters for them. Then then run the F8 procedure
on what model machine?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Di350 error code cof32
Replace the image unit.
11helpful
Error code cof32
ATDC setting error - COF32, run F8 & use actual value, do not reduce setting value. open sie cover to reset.
20helpful
2answers
REMEDY TO SOLVING ERRORS COF32 AND CO650 IN KONICA MINOLTA BIZHUB 211.
C0650 code is the scanner lamp home sensor is not working so the copier does not know where the scanner is clean first will require removal of the orginal glass (large one) the other code is the image unit, has it been replaced or repaired recently. To fix mite require a new image unit
2helpful
Fixing code cof32
The excess toner is under cleaning blade.Posible you emptied the developer.COF 32 ATDC sensor malfunctions.Tray ATDC gain level from 155 to 168.
5helpful
Fixing code cof32
You must have cleaned the developer in the right side of the image unit, the reason for the code because the sensor doesn't detect toner and developer. You don't mension the make and the model, I presume is a Minolta. If you tell me ,I can tell you how to sort that out.
GOOD LUCK.
17helpful
3answers
Code cof32
I removed Drum Unit, emptied excess toner, cleaned and installed. After short start-up code cof32 appeared.
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
