Please consult the event log for more details comes after the interactive logon process initialization has failed
SOURCE: Acer 5100 will not logon
Try it in SAFE MODE... this will fix errors... then restart the computer.
SOURCE: Acer Aspire 5100 will not log on
If you have a Finger Print scanner (on select models), it may have failed, if you do not have this device , you may have installed malware - try rebooting and after you see the Acer screen start tapping F8 to get to speacial boot menu - choose Safe Mode and see if you can log in. If still unable, you will have to perform a system recovery - Acer provides an alternate way to recover - when you start the computer you see the Acer logo screen - after this displays hold down the Alt Key by the spacebar and tap the F10 key at the top of the keyboard once or twice - this will start the Acer E-Recovery program - follow the on screen instructions.
SOURCE: LOGON PROCESS INITIALIZATION FAILURE
Assuming you are using Windows XP. There's some file corrupt or missing when you start your pc. If you have floopy disk you can boot disk, it not your can insert your Windows XP installer and then you can repair you OS.
SOURCE: When my computer loads and tries to go to the main
This might work (no guarantees)
Bring up task manager Ctrl+Alt+Delete and click the applications tab
Click on "New Task"
type in explorer.exe and click okay.
If it boots up run malwarebytes available here www.malwarebytes.org
run full scan and delete anything it catches.
Good luck
