Madison Damron Posted on Dec 19, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Turn table on Crosley CR86ph record players isn’t turning. But I can hear motor running? How can I fix this?
john h
Level 3:
Top Expert:
  • Crosley Master 29,497 Answers
  • Posted on Dec 19, 2018
john h
Crosley Master
Level 3:
Top Expert:
Answers
29497
Questions
0
Helped
7799649
Points
193476
5 Related Answers
Anonymous
  • Posted on Aug 20, 2008
SOURCE: Philips Gramophone record player repair
which model you have? 242? Philips truntables can be easily repaired only if you know where to take them for repairs. I am also living in bangalore.. and I am a vinyl, retro turntable collecter. just send me you phone # at redlag@gmail.com. I will be glad to guide you on this... cheers
Anonymous
  • 17 Answers
  • Posted on Feb 12, 2009
SOURCE: Needle slides across the record on Crosley 5 in 1 player
you have unscrewed the suspension screw?
also check the needle for dirt and dust... try blue tacking a 5p coin to the top on the needle to give it a little more weight, if the needle stays in place then the arm balance if off, and unless there is a mechanism to adjust that on this turntable then i guess its a return!
Anonymous
  • 38 Answers
  • Posted on Nov 04, 2009
SOURCE: will my autorama crosley cr712 record player work without
The record player will work with out a remote.
The CD will need a remote, for operation control.
The radio will work with out a remote
Anonymous
  • 17 Answers
  • Posted on Jul 24, 2010
SOURCE: I have a Crosley CR248 cd record player/recorder stopped working
If nothing lights up and the whole unit is dead, you may have a blown fuse, a bad power supply, or an electrical outlet that is not giving you power. (Don't laugh, it has happened to all of us... the "broken" thing wasn't plugged in or the outlet it was plugged into was off for some reason). Anyway, if the thing lights up and everything else in the system works except the turntable going 'round, perhaps there is a slipped or broken belt. Most late-model Crosley turntables have been belt drive, so the first thing to look at if everything else works is to press the buttons to start the record playing and then turn the record gently around with your finger on the label, making the whole platter turn clockwise when looking down at the record. Mechanically, the tonearm should cue up and pivot in to the record and it should gently drop onto the record. If you cue the tonearm up and move it in to the end of the last song on the LP and let it back down and turn the record again, it should follow the record's grooves into the center of the record and then lift and "park" the tonearm after everything is done. During the time the needle is on the record and you are turning the record, you should hear the record playing (it will sound bad, because you won't be turning at the right speed!), but that should indicate that the turntable is working mechanically and electrically.
If everything works like I mentioned except the record player won't make the record turn, the next step is to see why it isn't turning. you'll need to lift the plastic platter off the turntable. Most of these have a snap ring (usually a simple spring wire ring that doesn't go all the way around the center spindle. It may have an E-ring instead. Use a small screwdriver to pop this off and be sure to catch it, it might try to pop off the turntable and fly across the room! Lift the platter and you'll probably find a broken belt underneath. You'll have to replace that to make the records spin again. The hardest part is to locate a replacement belt! If nobody near you stocks belts (lol) then online outfits like LPGear.com can be a source. After you replace the belt and put the platter back on the player, remember to replace the snap ring. You might want to lubricate the platter's bearing with an appropriate lubricant, but that is your call as to whether that will be necessary. This is likely a styrene or simple thermoplastic plastic bearing, so be real careful what you use for a lubricant! if you're not sure, don't use anything! Like I said, it's not a difficult repair, it's just hard to find the part these days! Good Luck!
tomokeefe29
Tom OKeefe
  • 11 Answers
  • Posted on Apr 27, 2013
SOURCE: My Crosley CR49-TA won't revolve. It turns on, and
Most turntables are belt driven. Suggest you take a look inside but remember to unplug the deck first. Usually it's a simple case of slipping the belt back on.
Top Crosley Audio Players & Recorders Experts
Axel Gringmuth
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
