HP Photosmart D7460 Printer Logo
Posted on Aug 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Paper jam no paper jam D7460 - HP Photosmart D7460 Printer
Anonymous
Level 2:
Sniper:
  • Expert 52 Answers
  • Posted on Aug 04, 2009
Anonymous
Expert
Level 2:
Sniper:
Answers
52
Questions
0
Helped
25111
Points
210
After going through your problem, i think that there is a communication failure between your printer and computer, in such cases, it is common to get false error messages like paper jam, etc, even though there is no actual paper jam. I recommend u uninstall and reinstall the printer driver. Im sure your issue will be resolved.
Anonymous
Level 2:
  • Expert 61 Answers
Anonymous
Expert
Level 2:
Answers
61
Questions
0
Helped
12743
Points
109
Open and close any door(s) on the printer.....
4 Related Answers
sodeep
Sudeep Chatterjee
  • 3269 Answers
  • Posted on Mar 22, 2009
SOURCE: how to load 5x7 photo paper into hp photosmart D7460 ??
Simply set the page layout option to select from printer. Place the cut & proper sized paper in the inlet tray, adjust the sliders so that they just rest lightly against the edge of the paper. Remember only one slider moves and the other one remains fixed to one edge. Click print preview. You might get a message saying paper orientation is not right...should I adjust the printer automatically, click yes and behold it will print in Portrait or landscape mode depending on the matter. If it warns that output does not fit on the media(paper) then select fit to page option.....sodeep
Anonymous
  • 2306 Answers
  • Posted on Sep 17, 2009
SOURCE: Clear carriage jam -hp d7460
Carriage jam usually comes from ink on the clear encoder strip that runs across behind the carriage. You need a damp Q-tip to clean from one end to the other, The other thing, on the HP is the cleaning station on the right gets gummed up with old ink and won't go toward the back fully, stopping the carriage.
Anonymous
  • 109 Answers
  • Posted on Oct 21, 2009
SOURCE: My canon MP620 Paper Jam Pull out the Jam Paper Al
There are pieces of paper stock on the sensor, when the paper jam happened then you pull out the paper did you get the whole page of the paper or have missing pieces? open the paper guide, turn off and on the printer and observe the unusual objects in the roller, this error is caused by objects in the sensor.
Tinteiros
John Bradley
  • 88 Answers
  • Posted on Nov 02, 2009
SOURCE: My D7460 will not feed paper The screen says load
Usually this occurs when a printer has had fairly excessive use. This causes the rubber paper feed rollers to become shiny and then they are unable to grab the paper, or it grabs several sheets at the same time. Newer laser printers have now have grooved belt tracks to help prevent this problem.
The easiest way I have found is to BUFF the shiny tracks... Here´s how... Using a ladies nail file (sand paper type) Press the paper feed button to cause the rollers to slowly rotate and buff the rubber as it turns. Making sure no sand enters the rollers. If several sheets of paper feed at the same time. Pull them out and a trick to stop this happening is... to fan the paper before loading into the paper tray. The trapped air will allow the sheets to glide easier.
You can read more here:
How to Clean, Fix, Repair, Unclog, Dry, Clogged Print Heads on CANON, EPSON, HP, Lexmark, Dell, Olivetti etc…
Good Luck!
John P Bradley
Tinteiros (Ebay)
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
