Worked great for a while, and now almost every time i go to turn the volume down with the dial... it jumps up even louder. The only way I have found to turn down the volume is to mute the stereo and then turn it off and back on again so the volume goes back to zero and then I use the dial to turn it up.... this is, as you can imagine a huge headache... and I hate getting blasted @ full volume when I am trying to turn the volume down. Resetting factory settings seems to do nothing either. Any help or am I sol?
Ok my head unit is stuck on 10 with my valume and it wont change how can I fix that
How i can reset la anti-theft code for one xdvd710 dual
OK PEOPLE, I HAVE THE DUAL XDVD8181 just installed, you don't need to do any kind of code to get the video to bypass. this is what you have to do
Get a toggle switch, one that flips one way for ON, and the other way for OFF. connect parking brake wire (yellow/blue) to one end of the switch and the other end to the ground of the radio (Black wire) leave the switch in off position, turn on radio and insert dvd, when you get the blue screen, flip switch ON OFF ON wait 5 seconds and video will come on. That it fellas.
Do you have to flip it on / off / on everytime?
I have the same problem, and it ended up going so high that it damaged my rear speakers >:(.
i have the same problem.. its annoying.. everytime i get in my car its full volume.. if i try to use the knob it get louder as im truning it down..the screen flip out wants to work when it sees fit.. BOOOO peice of ****
