Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
asd-40
Do you have any other symptoms? Such as a red light error, usually if you only have sound and no image this generally means that the AV cable cannot be detected. Try the following...
1. Make sure that the AV cable is correctly connected to the Xbox 360 console.
2. Disconnect the AV cable from the Xbox 360 console, and then reconnect the AV cable to the Xbox 360 console.
3. Try wiping the
metal area of the AV pack with a dry cloth. The metal area is the end
that plugs into the console. Wipe the metal area thoroughly, and then
try the AV Pack again.
Please rate if at all useful, thanks!
SOURCE: xbox 360 with sound but no image
Make sure your av wires are properly connected, it may be faulty video wiring, if not than your 360 is more than likely defected.
SOURCE: my xbox 360 cables input
xbox repair in mumbai :- 9819767710/9867635653 ?xbox repair in mumbai :- 9819767710/9867635653 ?xbox repair in mumbai :- 9819767710/9867635653 ?xbox repair in mumbai :- 9819767710/9867635653 ?xbox repair in mumbai :- 9819767710/9867635653 ?
SOURCE: Xbox 360 not starting up
If you're using HDMI to connect, make sure the TV is on the correct input as the console will 'wait' for a valid signal before powering up fully (on some TV's).
Also check the colour of the Power Adapter when you have powered up the x360.
Here is a link to troubleshoot the power adapter based on the colour of the light on it:
http://support.xbox.com/support/en/us/nxe/hardware/console/setupyourconsole/connecttopowerlist.aspx
Hope this helps.
SOURCE: Xbox 360 Console: xbox 360 video not displaying but sounds works...
make sure the color cables a fastened tightly in the t.v.
same issue please help
i called the xbox support and they said it will take them 2-3 weeks to try to fix my xbox
