Sewing Machines Logo
Shirley Bagg Posted on Mar 14, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Making buttonholes - Sewing Machines
Jean DeLauche
Level 3:
  • Sewing Machines Master 2,911 Answers
  • Posted on Mar 14, 2018
Jean DeLauche
Level 3:
Answers
2911
Questions
Helped
1001706
Points
13031
Hello, Shirley -
Making buttonholes for clothing you are constructing varies depending upon the make and model of sewing machine.
Some sewing machine have built-in buttonhole making features, with a buttonhole foot which can be attached. Some machines require a buttonholer attachment.
Without knowing the make and model of your sewing machine, it is a challenge to advise you properly. You can add the make and model of your sewing machine by choosing Comment and typing in the information.
One thing you need to keep in mind when making a buttonhole: The actual opening should be 1/8 -1/4 of an inch larger than the diameter of the button.
Best wishes.
2answers
Hi can’t make the button hole big enough using the special one step Pfaff foot . Won’t go bigger than 8mm
It could be that 8mm is the limit for the buttonhole foot. You can try making buttonholes manually with the sewing machine. Not really difficult. Just need to be careful marking the buttonhole and stitching. Recommend practicing on scrap fabric before trying it on the project.
How to Make Buttonhole on Your Sewing Machine Sew4Home (several methods)
Creating Buttonhole Using Sewing Machine
how to sew buttonhole without buttonhole foot Google Search
Instructions for making a buttonhole
The method will depend on your make & model machine, although the vintage sewing machine buttonhole method will work on all zig-zag machines (just requires manually measuring and adjusting the stitch length & width during the process):
How to Use an Automatic Buttonhole Foot
Sew Buttonhole in 4 Steps on your Singer Sewing Machine
Sewing Buttonholes Without Buttonhole Foot
How to Sew Buttonholes with Regular Foot Sewing Tutorial with Alison Smith
How to sew buttonhole with an old machine
How to Sew Button hole tutorial
Sew Buttonhole without Buttonhole Foot by Create Kids Couture
Be sure there is a stabilizer between the fabric where the buttonhole is located so the fabric will not stretch or tear.
Where is the buttonhole stitch?
Difficult to assist without more machine information. FWIW, a lot of older machines do not have a buttonhole stitch, but it is easy to do as long as the machine has straight stitch and zig-zag options.
Making Buttonholes Without Special Feet
How to Sew Zigzag Patterns Making Button Hole Using Zigzag Stitch
It does not have 4 steps to do a button hole and will only stitch on the right hand side when I put it on the button stitch. How do I do the end pieces and the left hand side?
You can perform all the steps of a buttonhole without the buttonhole option (ask how sewists used to do it before sewing machines offered the buttonhole option). You'll just need a machine that can zig-zag.
There are a lot of web sites and tutorial videos available.
2answers
What is wrong with machine I have tried all the instructions and it makes a horible button hole
most sewing shops/fabric shops that sell or service machines have people who are willing to show you how to do it regardless of the make of your machine
there is a knack to the job that is difficult to print in instructions
Buttonhole Husqvarna 6430. When it is supposed to sew the right side of the buttonhole it just goes back over the left side. The machine doesn't do the two buttonhole lines next to each other . An
the machine probably needs to be serviced to see why it's not making
a buttonhole and see if the gear or cam for the zig zag stitch is
worn or damaged.
Pfaff 2170 will not make consistently sized buttonholes
Go to the following site regarding timing your machine. Are you placing a button in the buttonhole foot so the machine "knows" how long to make the buttonhole? If you have a button stop lever to the left of your needle bar, are you pulling it down and putting it in FRONT of the button stop so it can complete the rotation?
Try www.fixsewingmachine.com
Try http://www.manualowl.com
I have temporarily misplaced the instruction manual to my White 979 sewing machine. I need to put this shirt in todays mail and I have forgotten the direction to make a buttonhole. I s there a place I...
Automatic BUTTONHOLE making with 979:
  1. Carefully mark the position of buttonhole on your garment.
  2. Slide the button carrier and insert the button.
  3. Attach the buttonhole foot.
  4. Place the garment under the foot so that the needle pierces the fabric at the beginning of buttonhole.
  5. Lower the buttonhole lever and the presser foot lever.
  6. Push the buttonhole lever away from you.
  7. Start machine to complete entire buttonhole.
NOTE:
  • While making buttonholes, maintain an even sewing speed for uniform buttonholes.
  • When buttonholes are completed, be sure to push up the buttonhole lever as gar as it can go.
1helpful
Buttonholes
First be sure to follow the steps described in the manual for attaching the buttonholer.
Second, check that the buttonhole lever is pushed because it returns to it's unpushed state after a buttonhole is completed and therefore it will stitch in the same spot.
Also, try adjusting the stitch length. I've found that I can't make buttonholes while on the satin stich setting ( that little rectangle) but if I move it just a bit towards 1 it will manage to make the right stitches.
Bernina Activa 131: buttonhole problem
There are TWO buttons on the machine that have the little u-turn on them. Look for the other one. That is the one that makes the second half of the buttonhole. Look in the owner's manual, it may tell you where it is on your machine. I spent a long time swearing at my machine before I figured out that the reverse is not the only button with the u-turn arrow. The manual is not clear on this. Why they use the same symbol twice is beyond me. Mine is on the front of the machine, down by the needle. Hope this helps.
Top Sewing Machines Experts
ADMIN Andrew
ADMIN Andrew
CJ Rock
CJ Rock
Are you a Sewing Machine Expert? Answer questions, earn points and help others
