Home Security Logo
W
William Lewis Posted on Feb 20, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cannon Gun Safe. It will not stay locked. It will take my code and open but won't lock. The handle manually locks but will open without putting in code. I changed the battery and it did not help.
ADMIN Andrew
Level 3:
Top Expert:
  • Home Security Master 73,781 Answers
  • Posted on Jun 03, 2025
ADMIN Andrew
Level 3:
Top Expert:
Answers
73781
Questions
Helped
6295750
Points
431340
Old question resurrected by AI Answer bot.
Open the safe and remove the panel on the back of the door. Spray all the linkages and the solenoid with WD40 to lubricate all the moving parts. Operate the lock and handle with the panel off and the door open to check correct operation. The working are incredibly simple, battery, lock pad, solenoid and a handle.
https://www.google.com/search?q=Cannon+Gun+Safe+how+the+electronic+lock+works
5 Related Answers
Anonymous
  • 160 Answers
  • Posted on Nov 24, 2009
SOURCE: I can't reset by keypad on my cannon gun safe electronic key pad
First I would try the original numbers to see if you did change it. If the original numbers work then you need to start over. If they don't work then the new numbers you installed are there and you need to figure out what you punched in not what you meant to punch in.
Hope this Helps,
RSMITH972278
P.S. FOR FURTHER ASSISTANCE PLEASE PROVIDE MAKE AND MODEL
P.P.S. PLEASE RATE ME
Anonymous
  • Posted on Mar 18, 2010
SOURCE: how to change the combination of a Simplex pushbutton lock
Your screwed.
Anonymous
  • Posted on May 16, 2010
SOURCE: Brand new Sentury safe Csw3607 does not lock, handle stuck down.
I had the exact same problem... All you have to do is unscrew a long, skinny, silver screw on the inside of the door. This unlocks the handle and locking mechanisms. Would have been nice if that step was in the instructions!!! Good luck.
Anonymous
  • Posted on May 25, 2010
SOURCE: century safe lock , not able to open the combination lock oper b
just boughy it and instructions got thrown away by accident . I have keys but no combination please advise..... Numbers on door that are tagged on is: BJ-285913* an another sticker that says 50310 BJ285913 please advise...
Anonymous
  • Posted on Sep 13, 2010
SOURCE: I purchased a new Sentry
(1) sounds like the interior lock activation screw is still installed. it's the long screw on the inside of the door with the yellow tag; (2) when entering the code, make sure the key is turned to the right; (3) after entering the code, make sure you next press the program button. enter the code wrong three times and it locks up for two minutes.
Top Home Security Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Home Security Expert? Answer questions, earn points and help others
