SOURCE: The knob on the bottom
You *can* order parts from the manufacturer directly, but good luck
with that. The first time I called, and mind you their 1-800 # is a
quagmire of numeric menu selections before you ever get to talk to
someone, they said they would be happy to send me one but they were
out/backordered and that I should call back in 2 weeks. Instead of
putting me on some kind of list and sending me one when they got
more...Grrr! Then I tried calling back and made it, again, through the
menu maze only to find out they are in Eastern time. Super
frustrating!
But I also discovered that the flat head screwdriver is the best
temporary solution until I can get my hands on a replacement knob!
SOURCE: I need an owner's manual for the Wolfgang Puck Toaster Oven
go to www.wphousewares.com to download instruction manuel.
SOURCE: Where do i find a replacement knob for timer on
I contacted kitchenaid at 1-800-541-6390 and they graciously sent me a new one at no cost.
SOURCE: Labels on black and decker toaster oven worn off CT0650C
Top dial is Bake/Broil knob, it goes left to right. Starts with OFF @ 9 0-clock next is 100 dgre then @12 o-clock 180 Deg. is at top center next is 250 Deg. next 350 located opposite of off. Next @ 4 o-clock is 400 Deg. Next @ 5 o-clock is 450 Deg. and finally at the bottom at the 6 o-clock position is BROIL. The Center Knob is BAKE TIMER . Starts @ off position as 0, next @ 10 o-clock is 10-mins. Next @ 12 o-clock position is 20 mins. Next @ 2 o-clock pos. is 30 mins. Next @ 3 o-clock pos. is 40 mins. Next @ 5 o-clock pos. is 50 mins. Next and finial pos. is 60 mins. The Bottom knob is TOAST @ the 9 o-clock is is 0 next @ 11 o-clock pos. is Light , Next between the 12 & 1 o-clock pos. is MEDIUM and the final pos. @ 3 o-clock is DARK. TOAST.
SOURCE: Need knobs for Euro-pro convection toaster oven TO161
Take a look here Amazon com euro pro toaster oven on amazon. I'm pretty sure you can find something. cheers
