Photography Logo
Walter Nazloomian Karen Waters Posted on Jan 08, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to remove 128RC Manfrotto head from a Manfrotto 290XTA3
Tony Parsons
Level 3:
  • Manfrotto Master 6,407 Answers
  • Posted on Jan 08, 2018
Tony Parsons
Manfrotto Master
Level 3:
Answers
6407
Questions
Helped
1694108
Points
20281
Undo the three grub screws, then unscrew the tripod head anti-clockwise.
2 Related Answers
Anonymous
  • Posted on Feb 06, 2009
SOURCE: Removing Tripod head from center post on Manfrotto Modo 785B
I have the national geographic branded version. Here is how you remove the head.
(1) remove the center post from the tripod
(2) lock the ball head with the trigger lock
(3) grasp the body of the ball head with one hand and the center column with the other.
(4) turn counter clockwise.
If you're intending to replace the ballhead, be warned that the thread is non-standard. I have a new "plug" with a standard 1/4" thread made for free by the machinist at my job. I don't know how you would go about adapting it without such a capability.
MIke
  • 685 Answers
  • Posted on Sep 24, 2010
SOURCE: The Pan Tilt Head cannot be removed from my
Extend the center column, there are 3 screws underneath that when unscrewed will allow the head to be tightened or loosened. The head is screwed on about 4 or 5 revolutions. You will need a flat head screwdriver. Take the center column out if you need to to be able to get to the screws.
1helpful
How do I replace a leg release lever of a manfrotto 190XB? One of the three leg release levers is missing. I ordered a spare part (R190,304), but I don't know how to put it in place.
Hi Stefan
Possibly some bad news for you..., the Part #R190,304 you ordered is not made for the #190XB tripod..., it is for a model several years older (though it MAY fit)..., (see link for correct parts diagram)!!!!
http://www.manfrottospares.com/download/pdfs/190XB_20061025.pdf
To easiest way to replace one of the top leg castings is to first remove the centre column and then support the tripod in such a way that the (3) legs are not touching the ground (i.e.: all the weight is supported by the casting through which the centre column would normally mount. You will then need to undo the (3) screw (allen key style) that pierce this casting...., (the reason for wanting to support the tripod via the bottom of this casting is that all the small parts SHOULD stay in place when the top casting is separated from the lower casting. Once this has been done..., carefully remove the leg with the damaged top casting...., replace it (making sure the new one is facing the right direction) & then reverse the procedure.
Hope this helps
Peter
Manfrotto 128rc
Lee
Can you either take a picture of the offending part and post it..., or check out the following link to the parts diagram of your head and then indicate the part that is causing the problem? I am just not sure what you are asking.
Link:http://mediacdn.shopatron.com/media/mfg/2747/media_document/live_2/128RC_20020703.pdf?1272346400
Peter
Nov 02, 2013 • Photography
Tripod leg stuck
loosen the allen head screw for that legs snap lock
Hi, I have just bought the 190CXPRO3 carbon fibre
Little confused here. Is the head the part you want to detach from an older set of legs? Do you want to remove center post from new legs or old legs. The base plate remains on the center post/ Aftre removing 3 set screws, and you want to remove the head from the baseplate and it will not turn, grap slip joint pliers or a pipe wrench, wrap the jaws with cloth ( to prevent marring of head or legs) and while holding head with wrench, have someone else turn legs
1helpful
I'm trying to attach a Canon EOS Rebel XS to a Manfrotto 190XPROB tripod, but the tripod socket on the camera is too small. How do I attach them?
You need a head. The tripod has a standardized screw for accepting a tripod head, which is a larger screw than for the tripod mount on the camera. There are a variety of heads available, ball heads, three-axis heads, geared heads, pan-and-tilt heads, and more.
Here's a page showing Manfrotto heads:
http://www.manfrotto.com/Jahia/site/manfrotto/cache/off/pid/1888?livid=80&idx=80
Aug 11, 2010 • Cameras
9helpful
3answers
Breakdown Manfrotto 3265 ball head from 190xb tripod
IT SOME TIMES TAKES A LOT OF EFFORT TO SEPARTE THE HEAD FROM THE TRIPOD. MAKE SURE YOU REMOVE THE 3 LITTLE SCREWS FROM BELOW THE HEAD, AND MAKE SURE THE TRIPOD AND HEAD ARE NOT COLD. IF THEYA RE WARM THEY WILL SEPARATE EASIER.
Bogen Tripods, changing heads.
I searched around and all I can find is this: http://www.manfrotto.com/Jahia/site/manfrotto/pid/2477
Top Manfrotto Photography Experts
Tony Parsons
Tony Parsons
MIke
Anonymous
Are you a Manfrotto Photography Expert? Answer questions, earn points and help others
