It has been some time since I have done this but if I remember correctly, the replacement glass comes with a special tool for the trim around the glass and instructions. I suggest calling a supplier, such as Restaurant Parts and More, Heritage Parts, or PartsTown and ask if this is still the case that the tool and instructions are included with the glass.
SOURCE: Igniter stays lit entire time oven is on Blodgett dfg 100-1
I have seen this happen when a hole develops near where the ignitor is mounted. The excess gass overheats the ignitor and burns it up. What I do in a case like that is slide a c clamp over the burner and cover the hole.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: Blodgett Oven won't light
you are improving the voltage across the flame sensor . it probably is just short of being in range, failure to meet the proper micro amps the sensor produces will cause lock out and no ignition. sometimes you can simply adjust the sensor to hit flame better and it will work much better...
SOURCE: i have a blodgett dfg-50 that wont ignite the
Call Toll Free: (800) 331-5842 and ask for tech support or go to http://www.blodgett.com/contact_us.htm
Hope this helps, fwiw.
Oven repair in Santa Ana, CA
Appliance repair in Santa Ana, CA
SOURCE: need to change over blodgett
No keep the same spring but change the orifice and adjust the air mixture to get a clean burn
