SOURCE: installing carbon brushes on Bosch WFK 2401
Remove rear panel of washer.
Remove drive belt.
Unscrew the 2 bolts that hold motor to tub back.
Remove motor plug
Lever notor back with a screwdriver or similar, keeping a firm hold on motor.and remove motor
At the rear end of motor away from pulley you will see the brushes and the armature.
Remove brushes, and if there is less than 4 or 5mm of carbon left, then replace them.
Lightly clean the armature with emery cloth.
Refit in reverse order. Test.
Plz rate my solution.
Thanks.
SOURCE: how do I replace the carbon brushes?
Go to the link below there is a video How To..
http://www.videojug.com/webvideo/how-to-replace-hotpoint-carbon-brushes-in-your-washing-machine
SOURCE: Replacement carbon brushes, where to buy.
Just go to the Clark tools site & brushes can be bought on-line & sent to you.
http://www.clarkeusa.com/support.htm
Here is the link for you.
Best of luck
Ian Wallace
Testimonial: "Don't know why that site exists. Clarke filed for chapter 11 in Feb. 09. April 30th article in the Toledo Blade states they went out of business."
SOURCE: where to find replacement carbon brushes Campbell Hausfeld pressure washer pw1350
Parts for Campbell Hausfeld can be found at www.chpower.com. Campbell Hausfeld does not however, sell motor parts for many of their tools. You would have to call their 800 number and speak with a parts person to determine availability. You may be able to purchase a close match at a local True Value hardware store. They sell a variety of brushes for many major brands of tools. Purchase a slightly larger set of brushes and sand them to size. If the connector is different, cut off the old connector and solder it to the new brush.
SOURCE: jeanie rub massager
Out-of-Warranty Service
Core Products will repair most Jeanie Rub Massagers after the warranty has expired. Some of the very early models can not be repaired but can be returned for a $50.00 credit towards a new unit. It is difficult to determine the extent of the repair until the unit is inspected however, we guarantee the service call will not exceed $89.00 plus shipping. 1-800-338-7014 Complete Service Package - $89.00 + $13.00 Shipping Cord Replacement - $25.00 + $13.00 Shipping There is a 90-day warranty on any service that is performed by Core Products International. Where to send it
Basic Service Package - $49.00 + $13.00 Shipping
- Cleaning
- Replace worn parts & pad
- Cleaning
- Replace motor
- Replace worn cord
Core Products International, Inc.
RETURNS DEPARTMENT
1505 Parker Ave, PO Box 627
Chetek, WI 54728
If you have any questions regarding our service,
please call 1-800-338-7014.
