p
philani Posted on Aug 20, 2017
INTERPOLATING LINEAR REGRESSION USING sHARP CALCULATOR EL-W535HT WriteView
5 Related Answers
k24674
  • 8093 Answers
  • Posted on Sep 14, 2009
SOURCE: HOW DO YOU ENTER r2 ON A TEXAS INSTRUMENT CALCULATOR?
No need to enter R squared. If it has meaning it will display in the stats variables screen ( 2nd F7 ).
Hope it helps.
k24674
  • 8093 Answers
  • Posted on Oct 04, 2009
SOURCE: How do you do a linear regression graph on a casio
I am aware that the solution provided below is valid for the CFX/FX-9850G/GB/ but I will supply it. I remain convinced it will help you for your calculator.
In the main menu select [STAT] icon to enter Stat mode and display the statistical data lists. Use the satistical data lists to input data and perform statistical calculations. Use the arrows to move the highlighting around the lists.
Exemple: Enter the following values in List 1
1st line enter 90 [EXE]
2nd line 85 [EXE]
3 79 [EXE]
4 75 [EXE]
5 70 [EXE]
6 68 [EXE]
7 56 [EXE]
When finished you press [F2:Calc], then [F1:1Var] and the statistical results appear on screen.
Title of screen : 1-Variable
x bar =74.7142857
Capital Sigma x= 523
Capita Sigma X squared = 39851
x lower case sigma n = 10.5249945
x lower case sigma n-1= 11.3682934
n = 7
Scroll down with Down arrow to access other data
minX =56
Q1=68
Med =75
Q3=85
Xbar -x lower case sigma n =64.1892911
x bar + x lower case sigma n = 85.2392802
maxX=90
Mod=90
All you have to do now, is to look at the theory you learned and interpret what these values mean.
Hope it helps.
k24674
  • 8093 Answers
  • Posted on Sep 07, 2010
SOURCE: how do i do linear regression on this calculator
I am sorry but I will have to assume that you know how to enter the data.
Once you enter your data [MENU][STAT], press [F1:Graph], select Gph1, Gph2, or Gph3. Once the graph of the experimental data is drawn, you will have access to the diverse regression models. Your choices are [X:Linear] [Med-Med], [Quadratic :X^2] [Cubic;X^3] [Quartic: X^2]. Press [F6] to scroll right to access the others: [Logarithmic:LOG], [Exponential :EXP], [Power :Pwr] and [Sinusoidal: Sin]
After you select a model and press [EXE], the screen displays the equation and its various coefficients. On that same screen, you have a menu option [F6:Draw]. If you select it, the regression curve will be drawn on the same screen as your statistical graph. This allows you to judge if the fit is good. If it is not, you have the option to choose another model.
The other option [F5:Copy] allows you to save the regression equation in the Y1, Y2, etc. variables.
PS If you do not know how to enter data post a comment to this effect and I will see what I can do to help you.
Testimonial: "very thorough and easy to understand; thanks"
Anonymous
  • Posted on Nov 28, 2010
SOURCE: how can we do linear interpolation in casio fx-991ES calculator
how solve interpolation by casio fx 991 ex
Anonymous
  • Posted on Aug 02, 2011
SOURCE: Hello, I have a calculator
the mode key is giving error and the number keys are not working
Top Sharp Office Equipment & Supplies Experts
George Mclaughlin
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
