Kitchen Appliances - Others Logo
Posted on Mar 08, 2017
I need to replace the cuisinart griddler gr 4n heating coils because the upper one does not heat at all
5 Related Answers
Anonymous
  • Posted on Nov 07, 2008
SOURCE: Oven does not heat
i have had a similar problem before and was fixed by replacing a fuse check to see if you have 2 fuses if not then the next step is to measure the resistance across coil it wont be 0ohms cos if it is your back to a blown fuse instead you should have a resistance across it i suspect you will see a open circuit meaning u need to buy a new coil for your top oven
hope this helps
Anonymous
  • Posted on Dec 21, 2008
SOURCE: Stuck Grill plates
What happens is that the upper post (see the back of the plates; there's a quarter inch wide post) slides into a slot not designed for it (too small). To fix, find the post. Slide a table knife in between the plate and the griddler, and twist. This should un-jam the post and free the plate.
cactus bob
BOB BROWER
  • 267 Answers
  • Posted on Feb 25, 2009
SOURCE: sunbeam toaster oven upper heating coil not working
the part (element) cannot be bought , its connectors are welded into place ........ if you realy love your oven , you can get one by shopping in a goodwill store for a used oven and cut the element out and cut and weld the element into your oven ........ this does work ,i have done it
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
  • Posted on Feb 27, 2009
SOURCE: I need an instruction manual for the cuisinart griddler gourmet
The GRID-8PC is the Costco version of the GR-4 - the functions are the same - there are only cosmetic differences. Here is the manual for the GR-4:
http://www.cuisinart.com/share/man/397_man.pdf
-Tha Mp3 Doctor
hunter19_46m
Curtis Sewell
  • 7482 Answers
  • Posted on Nov 13, 2009
SOURCE: ge dryer model DVL223EA0WW service manual to replace heating coil
Try this website, they will have everything you need.
http://www.repairclinic.com/SSPartDetail.aspx?PartID=2512&Acc=1&PPStack=1
Good luck,I hope this helps
Top Cuisinart Kitchen Appliances - Others Experts
Narseman
Paul Bade
Dennis
Are you a Cuisinart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
