Panasonic Workio DP-2330 Printer Logo
Posted on Jul 21, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Clear fuser code E4-01 - Panasonic Workio DP-2330 Printer
dholaday
Level 3:
Master:
Sergeant:
  • Master 226 Answers
  • Posted on Jul 21, 2009
 dholaday
Master
Level 3:
Master:
Sergeant:
Answers
226
Questions
0
Helped
96665
Points
1179
Press "function"..while holding down "function"-- press "original size"..while holding down "function" and "original size"-- press the #3 on the #pad.. to exit menu mode press "function" and while holding it down press the "clear" button
i hope this helps
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
HP Color LaserJet Enterprise MFP M578. Error code 13.b2.ff.
Question edited for clarity 'make model error'.
Generic Paper Jam code for a jam in the fuser.
Video
Clear Paper Jam 13.B9, 13.B2, 13.FF Fuser - YouTube
https://www.youtube.com > watch
PREVIEW
1:05 No audio. Learn how to clear paper jams in the 13.B9, 13.B2, 13.FF fuser for HP Color LaserJet M65x, E650xx, E651xx and MFP M68x, E675xx, ...
YouTube · HP Support · May 19, 2020
HP LaserJet Enterprise M4555 MFP Printers - 13.B2.FF Error
https://support.hp.com > ca-en > document
Issue: A 13.B2.FF paper jam error appears on the control panel when paper is jammed in the top of the printer. ... Check the printer for jammed paper and clear ...
Missing: m578 ‎' Must include: m578
PREVIEW
HP LaserJet Enterprise MFP M577 - 13.B2.FF - PrintCopy .info
https://printcopy.info > code=13.B2.FF
2helpful
4answers
Reset Error codes
E000001-0002 refers to the fuser assy either getting to hot or not hot enough. Fuser error codes cannot be reset by power cycling the machine even though that is what the display tells you to do. In order to reset the fuser error code you must enter the service mode & reset the code. To enter the service mode:
press"Additional Functions" button (looks like a picture of a head with a star inside)
press the #2 and #8 at the same time (simultaneousley)
press "additional functions" again
The display should show a choice of
copier,feeder,sorter,fax,or board service modes
Select copier
select clear
select ERR
press OK
Turn power off & back on.
After clearing error stay at the machine to see if it comes to ready. The fuser assy can reach 139 degrees C.(Water boils @ 100C) The error can only be cleared through the service mode because a technician should inspect the fuser to verify there is nothing faulty that could possibly start a fire. If you enter the service mode & clear the error, power cycle the machine & during warm up the machine throws a code again- turn it off, unplug it & call a tech for fuser repair.
How to solve E000001-0002 canon ir3300 error code
E000001-0002 refers to the fuser assy either getting to hot or not hot enough. Fuser error codes cannot be reset by power cycling the machine even though that is what the display tells you to do. In order to reset the fuser error code you must enter the service mode & reset the code. To enter the service mode: press"Additional Functions" button (looks like a picture of a head with a star inside) press the #2 and #8 at the same time (simultaneousley) press "additional functions" again The display should show a choice of copier,feeder,sorter,fax,or board service modes Select copier select clear select ERR press OK Turn power off & back on. ****IMPORTANT**** After clearing error stay at the machine to see if it comes to ready. The fuser assy can reach 139 degrees C.(Water boils @ 100C) The error can only be cleared through the service mode because a technician should inspect the fuser to verify there is nothing faulty that could possibly start a fire. If you enter the service mode & clear the error, power cycle the machine & during warm up the machine throws a code again- turn it off, unplug it & call a tech for fuser repair. Good Luck!! I can be reached @ bspier@carlsonsupplies.com if you have any questions.
How do I clear SC542 error?
That is a fuser fault code will need to repair fuser first. If you buy the fuser might come with instructions to reset code.
1helpful
Canon code E000001-0002
press the #2 and #8 at the same time (simultaneously)
Select copier
select clear
select ERR
press OK
****IMPORTANT****
After clearing error stay at the machine to see if it comes to ready. The fuser assy can reach 139 degrees C.(Water boils at 100C) The error can only be cleared through the service mode because a technician should inspect the fuser to verify there is nothing faulty that could possibly start a fire. If you enter the service mode & clear the error, power cycle the machine & during warm up the machine throws a code again- turn it off, unplug it & call a tech for fuser repair.
1helpful
I am getting error code E000001-0002 in my IMAGE COPPIER 3545.... how to solve it
Select copier
select clear
select ERR
press OK
****IMPORTANT****
1helpful
Ir6000 error code e246-0002
Select copier
select clear
select ERR
press OK
****IMPORTANT****
The fuser assembly light has come on and my copier will not work. It is a Xerox XC1040. Do I need to replace the entire assembly cartridge ?
You can clear the Fuser error by entering diagnostics. Your fuser may need to be repaired though, so your error might return.
Turn on the power and within 4 seconds press the following sequence: 'Clear', 'Exposure Mode', 'Clear', 'Exposure Mode. The screen will go blank.
To clear the fuser code, select '14' followed by 'Print', then exit diagnostics.
The fuser 126K07390 has been discontinued but people can sell the sub-parts or rebuild them for you.
Whit Item, Inc.
8helpful
Error code E00007-0000
This Error code means that the fuser film is not reading the home postion. You will have to replace the fuser film or replace the fuser unit. Untill it is repaired you will not clear the code. Good Luck
4helpful
2answers
Error code h5-01 appeared on my sharpmar-507
Check the fuser unit and make sure its installed correctly.
Top Panasonic Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
