Kitchen Ranges Logo
D
Darrell Posted on Oct 03, 2016
How do I remove and replace the selector switch fro a Viking Range Model# RDSCE2305BSS
I don't see any screws to take the control panel off to get to the selector switch
5 Related Answers
Anonymous
  • 1665 Answers
  • Posted on Feb 16, 2008
SOURCE: KitchenAid Electric Range Model Ker807PSS01,Removing Control Panel
See usefull links:
http://www.partadvantage.com/store/categories/wp/KERA807PSS01
http://www.partadvantage.com/store/spider/wp/69
Dave Harrison
  • 114 Answers
  • Posted on Dec 13, 2008
SOURCE: GE model JKP13GOP2BG control panel faulty ( F1 code)
Often times when someone makes an attempt to "repair" a control, it does not hold up. Replace the entire control. Don't waste your time. You will also get a year warranty on a replacement control.
Anonymous
  • 30 Answers
  • Posted on Jul 02, 2010
SOURCE: replacing PB010036 Bake / Broil Thermostat Viking
you do not need to take apart any switches, all you need - unplug it from power, open front panel (2 screw on each side) remove all knobs, there is 3 more screws behind them). unscrew thermostat 2 screws behind knob. open top part of stove, remove grates and cover. you will see wires to thermostat unplug them and plug one by one to new thermostat. remove old thermostat from inside the oven (it has bracket inside). put the new one. close everything back.
appliancesrepairla.com - viking repair LA
TheMobilian
Dan Webster
  • 8221 Answers
  • Posted on Jul 21, 2010
SOURCE: I have a Viking Gas 30
Viking manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Anonymous
  • Posted on Jul 09, 2011
SOURCE: oven control, possibly thermostat or oven selector switch
my dacor ER36G oven will not ignite. The top range works perfectly. When I turn on the oven, I don't even hear the gas or the ignition sequence as I used to. The heat preset light just blinks and the oven will not engage. I have reset the circuit breakers just in case, but nothing works.
Top Viking Kitchen Ranges Experts
Paul Carew
Paul Bade
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
