I just bought mine and ran into the same problem. The fix is easy. First you need to make sure that the software is correctly installed. I installed mine and when trying to connect, couldn't. I had the unit turned on.
a. Because of reading the manual, I turned off my calculator - reconnected it to the computer via the cable. Had the CD (Casio CD) in the drive. The computer reinstalled the software after it auto-turned on the calculator and it worked.
b. Next time I ran into the problem. I had just had it connected to the computer and was editing a program. I exited the calculator and later tried to re-connect and couldn't.
I found that I had to make sure that the calculator is off. Also, you have to make sure that on the software (if it is open all the while) you hit the button at the left side window for the calculator that tells it to disconnect. If it is shown to be disconnected, the connect the calculator while off. It will auto-connect. The rest is easy.
When the calculator is on and you have a "No open File" message, and you have made sure that the wire is connected to both the computer and the calculator:
You exit onto the main screen; next, access the link menu, click on receive. Go to your Fa-124 program, and click on the small, (quite small) icon at the first left window's upper corner - it shows two computers connected. This established the connection and takes about 20 seconds to run.
Have same problem
i have connection problem with pc, i have windows xp
Same :(
Same :(
the same ay
me too
