SOURCE: canon pixma mp530 problem error code 5100
i had the same problem. aall i did was open the printer up and moved the thing that holds the cartridges to the middle by hand. mine seems to be working fine. post again if its still not working.
SOURCE: Error Code 5100
Carriage error. Paper or the print mechanism is blocked.
It
could mean the rollers don't grip the paper, there is torn paper
keeping the rollers from turning, the paper can't stick to the rollers
etc.,
http://noel.bouvet.free.fr/ip4200/Canon%2520Servicemanual_ip4200.pdf
SOURCE: error 5100
- Carriage unit
- Timing **** strip film
- Logic board ***'y
- Carriage motor problem
SOURCE: Error 5100 on my canon mx 310.
the 5100 is the carriage error and can be caused by 4 different sensors. First off the "Timing Strip" that passes through the back of the Carriage Assembly can be contaminated with ink spots and this needs to be cleaned. Open the cover and use your flashlight to examine the timing strip as much as you can see. You really don't have much access to this strip unless you remove the covers,..and doing that is considerable work. The other items that can cause this error are the sensor inside the carriage unit, the drive motor for the carriage asm, and of course the main logic card. However, 99.6% of the time it is the Timing strip which is easitly contaminated with splattered ink.
