Canon imageRUNNER 1133A Laser Multifunction Printer - Monochrome - Pla Logo
I
Ifra sow Posted on May 12, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It appears code e733 - Canon imageRUNNER 1133A Laser Multifunction Printer - Monochrome - Pla
Tall Tiger
Level 2:
Novelist:
  • Expert 106 Answers
  • Posted on Jun 13, 2016
Tall Tiger
Expert
Level 2:
Novelist:
Answers
106
Questions
0
Helped
44988
Points
228
This is a potential answer, taken from a series of Image Runner 1133A complaints with the e733 error .....
Check the voltage to ensure that the machine is getting the proper voltage. According to this error code, the voltage supply is not consistent or the power fluctuates on the receptacle where the printer is plugged in. To provide the printer with a consistent source of "computer grade power", read the notes below:
Most printers require "computer grade voltage".
The best way to supply "computer grade voltage is to use an APC battery backup. Ensure that the battery backup is capable of running the proper amperage needing by the printer. (check the printer specifications).
http://www.apc.com/shop/us/en/categories/power/uninterruptible-power-supply-ups-/computer-and-peripheral/back-ups/_/N-1nzwthz
You might contact APC to see if they will allow you to try a Battery Backup to see if it will correct the power problem.
Find a supplier that will enable you to return the product if that does not fix the discrepancy. (usually a well known electronics or dept. store that will accept returns with a receipt within "x" number of days);
That will enable you to test the battery backup with the printer to see if it fixes the problem.
Canon ImageRUNNER 3245 IR3245. Error code E000733 on ir3245 only on back to back copy. No problem in single copy
Question edited for clarity, add maker and model series.
Question moved to correct category.
Error Code e000733-0000 on Canon iR-ADV C2230
Copytechnet https://www.copytechnet.com > ... > Canon
Nov 26, 2020 - Check the connection of the Flexible Cable between the DC Controller PCB (UN9) and the Main Controller PCB2. -- removed and re-connected ribbon ...
Thread: Canon IR3245 E733-0010 & E197-0001 error codes
Jul 26, 2014
ir5075 E733-0010 - Copytechnet
Jul 14, 2011
Error Code CANON IR ADV 4035i E-733-0010 - Copytechnet
Dec 19, 2019
Canon IR3300 error code E000733-0001 - Copytechnet
Oct 9, 2007
More results from www.copytechnet.com
Why my canon ir1133 printer is showing e733/0000 error message?
ERROR E733-0000 Stops printing and shows sign "Turn ...
www.fixya.com/support/t21602993-error_e733_0000
Nov 20, 2013 - ERROR E733-0000 Stops printing and shows sign "Turn main power ON". Error ... error message when printing d1350 imageclass. Jan 03 ...
Canon ir 6000 ranning copy machine hang 2minet before e733
Dear
1) Turn off and then on the main power switch. Is the problem corrected?
YES: Check the operation once again; if normal, end the work.
Check Connectors, DC controller PCB
2) Is the connection of the connector (J1015) on the main controller
PCB and the connector (J122) on the DC controller PCB normal?
Further, is the cable between these connectors normal?
NO: Correct the connectors/cable.
YES: Replace the DC controller PCB.
Thanks.
2answers
ERROR E733-0000
Hello I have the same problem my canon still showing error e7330000.Help me fix the problem.
1helpful
Errore 000732-0001
getfile.asp?rid=1258 October 7, 2004 getfile.asp?rid=3215 Product : imageRUNNER C3200 Title : E732 and E733 Error Codes Problem :
Ongoing issues with error codes E732 and E733.
Solution :
Reseat the ribbon cables between the Reader Controller and the Interface PCB (FH2-6984-000 & FH2-6983-000. If the problem persists, replace the Reader Controller PCB (FG3-2570-000), and the Interface PCB (FM2-0036-000) at the same time. Canon USA, Inc. Systems & Technical Support Division
1helpful
My canon ir 3200 have a code error E 732 I dont now what to do
getfile.asp?rid=1258 March 3, 2009 getfile.asp?rid=3215 Product : imageRUNNER C3200 / 2620 / 3220 Title : E732 and E733 are Displayed, when Copying off the Glass or when using the DADF
Error :
Error codes of E732 and E733 are displayed, when copying off the glass or when using the DADF. The Control Panel would go blank and the processing data light would continue to blink. After a few minutes in this state; the copier was rebooted and the codes would resolve themselves, but would eventually return.
Workaround :
First, try reseating all the connectors to the Reader Controller, Interface PCB, and DDI-S PCB. Next,
check for proper voltage to all three boards.
In this case, a defective DC Fuse PCB caused the error codes. An intermittent loss of voltage to the Reader Unit caused the machine to code out.
Note:
The part number for the DC Fuse PCB is FG3-3020-020.
6helpful
2answers
E000733-0001 error code
E733 0001 - A fault is detected by the main controller PCB in the communication between the DC controller PCB and the main controller PCB.
Main cause The connector has poor connection. The DC controller PCB is faulty.
Action
1. Connector, DC controller PCB Is the connection between the connector J1015 on the main controller PCB and the conductor J316 on the DC controlled PCB normal?
NO: Correct the connection.
40helpful
3answers
Cannon image runner 2200 error code E000002-0000, how do I fix it?
E002/E000/E003/E261/E733 Error code: Due to AC line noise Error Code
Symptom E002/E000/E003/E261/E733: due to AC line noise. Description E002/E000/E003/E261/E733 occur due to AC line noise.
If the above error codes are frequently recorded in the error log, they might concern AC line noise. Cause When the machine tries to detect a Zero-cross signal of AC line, it will fail if a noise occurred around the zero-cross point. Since the fixing temperature is controlled based on the zero-cross signal, there is a possibility that the fixing temperature could not rise properly if a noise occurs several times. Field Remedy Replace the Switching Regulator PCB ***'y with a new one.
120V: FH3-2613
220V/240V: FH3-2614
The circuit has been modified to resist a noise. REMEDY Caution
 Press (* then 2 and 8 together then *)you are in service mode monitor:
To clear the error, execute the following in service mode: COPIER>FUNCTION>CLEAR>ERR.
GOOD LUCK MATE ......KINDLY RATE ME !!!! THANKS.
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
