Konica Minolta C6500 C5500 C6501 C6000 C7000 Developer Set C/m/y/k Dv610 Logo
Avery Marder Posted on May 06, 2016
Error code 3101 - Konica Minolta C6500 C5500 C6501 C6000 C7000 Developer Set C/m/y/k Dv610
Johnny
Level 1:
New Friend:
  • Contributor 43 Answers
  • Posted on May 06, 2016
Johnny
Contributor
Level 1:
New Friend:
Answers
43
Questions
0
Helped
14537
Points
96
Generally, C-3101 refers to a motor problem. Possibly the drive board. No clues on a simple fix. See if is still under warranty.
How to clear konica minolta360 error code c 3101
Replace the fuser unit. then reset, with procedure:
By Opening/closing the right door
Try this site as a start
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2answers
Where can I get a free downloadable manual for the Necchi 3101 FA?
Necchi Sewing Machine 3101 FA Manual - I Fix Machines
www.ifixmachines.com/.../1619-necchi-sewing-machine-3101-fa-manua...
PDF replacement manual, owners guide,instruction manual for your Necchi ... lost or damaged Necchi sewing machine model 3101 FA instruction manual.These manualsare downloadable and you'll need the free adobe reader to open them.
1helpful
5helpful
2answers
When i send to e-mail it pops up with a 3101 send error...please help
3101: SMTP Authentication error. Consult with Your network
administrator to verify that your Login Account, Name and
Login Paswrod required for SMTP Authentication are correct.
1helpful
Compatability
The Kenwood TK-3200LU15 is the 2Watt replacment model for the TK-3101. the TK-3202 or TK-3203 are 4 watt models that can be used. Although, they have to be programmed with the frequencies and codes you are using. The TK3101 came with defualt GMRS/FRS frequencies.
HiTechWireless.com
1helpful
Necchi 3101
if you have e-mail I can scan and send you the diagram.
2answers
Kenwood TK-3101 is sensitive to Motorcycle RF
After a lot of experimenting, I decided to try powering the Autocom with a 9v battery and that fixed the issue. Evidently, the power from the bike was dirty - I'll have to filter the power line, find a different place to tap into or remain battery powered.
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
