SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
Posted on Nov 18, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Computer does not recognize the usb - SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
arben pllana
Level 3:
  • Master 1,006 Answers
  • Posted on Nov 18, 2007
arben pllana
Master
Level 3:
Answers
1006
Questions
0
Helped
523649
Points
2367
Possibilities:
1) One of your USB devices have faulted, or is causing a resource conflict (or similar)
-- Remove all USB devices, and reboot.
2) Your USB chip/ports have been damaged.
-- Find a spare HardDisk or bacjup your data and re-install Windows and see how that goes.
3) Your Power Supply Unit (PSU) isnt supplying enough power to your PC (usually caused by a Video card upgrade). Try a more powerful PSU ... 400watts should do the trick
4) Bad memory (RAM) can cause wierd problems. run memtest for an hour to make sure your memory is ok
It seems that many people are still getting the 'USB Device not Recognized' problem from time to time. Unfortunately there is no easy fix.
Firstly, it's recommended that you make sure every one of your motherboard drivers are completely up-to-date, but you probably already knew that.
In XP, after a USB port isn't used for a long while the USB driver built into the OS sets the OHCI controller to suspend. When you plug a device back in, it can sometimes fail to 'wake up' properly. This problem was supposedly fixed in SP1 but there is a related registry hack that may still be able to help.
Run regedt32.exe and navigate to;
HKEY_LOCAL_Machine\SYSTEM\CurrentControlSet\Services\Usb
Create the Usb key if it doesn't already exist. Under this key, create a new DWORD value called DisableSelectiveSuspend and give it a value of 1. Then restart the PC.
A long shot perhaps, but I recall having similar problems with a USB hub built into my Microsoft keyboard and adding this key seemed to solve it. It wouldn't hurt in trying .
Alternatively, removing all entries relating to USB in Device Manager and all associated USB drivers will force XP into refreshing the USB driver stack.
Begin by unplugging all USB devices, then use Add/Remove Programs in Control Panel to uninstall any USB driver software. Next, boot up into safe mode and go to Device Manager. Once in device manager make sure 'Show hidden devices' is checked under the View menu. Uninstall all device entries in this order;
1. USB peripheral devices (printers etc.)
2. HID and/or Composite USB (Human Interface Devices) You're using PS/2 input devices so you may not have this entry.
3. USB Root Hub(s)
4. USB Host Controller(s) (Universal or Enhanced Host Controllers)
Then boot back into Windows (not safe mode) and it should populate the Root Hubs & Host controllers again. Proceed to plug your USB devices back in, starting with your powered hub. Be aware that most USB printers and scanners need to have their drivers installed first before you plug them in.
Hopefully some of this may be of help, let us know how you get on.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 14, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
622
Points
Here’s an interesting tutorial covering troubleshooting USB sticks. One of the hints here could be all you need:
http://filetonic.com/blog/2009/07/14/reformatted-pc-cannot-read-usb-sticks/
Anonymous
Level 1:
  • Posted on Jul 05, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
622
Points
I was checking some of the files on my usb. When it became unresponsive I rebooted it. After doing so, my usb ports wouldn't recognize any usbs(camera, printer, etc.) I kept trying and I got them to work...
Hi. If your saying that you're USB is not being recognize by your computer then you should try that USB on a different machine and try if its working there, and if yes the problem is with your computer you just need to update the drivers on your computer to recognize your USB, and if not I think the USB has the hardware issue. Hope This Helps
3answers
My adaptor is not recognized in my USB ports I installed the router and it completes all of its connection checks. I am trying to install the adaptor on a remote computer (in the basement) and that...
Here's what you can do since this is a USB wireless adapter, first connect the USB adapter on a different USB port on the computer better if you connect it on the back USB port of the computer tower and check if the computer will recognize it and if its recognize you can already continue with the software installation , but if not you can restart first the computer and check if the adapter will be recognized if still not the next thing to do here just to know if the adapter is good or bad is to connect it on a different computer and just to check if it will be recognized once its connected to a USB port , because a device should be automatically will be recognized by a computer once you connect it so if its still not recognized by a different computer adapter is bad...
My computer is not recognizing my external usb
Try to plug it in another hub, if your computer still doesn't recognize it, try plugging it in another computer and see if that computer recognizes it. If it does, then there might be something wrong with other computer. If it doesn't, then there might be driver issues with your USB.
Usb device not recognize
You mentioned that you uninstalled the unknown device from the Device manager. If you uninstall it then connected your usb flash drive you will see an error again on your device manager. This means that the driver for your usb port is not properly installed.
To install it, visit dell website, look for the model of your machine and locate the driver, download it then install from your machine.
1helpful
2answers
USB device not recognized
This solution worked for me when I got the USB device not recognized message:
http://www.infobarrel.com/USB_Port_Repair
It can be quite frustrating. I've heard that older computers are more likely to have the USB device not recognized message.
1helpful
My computer dont recognized my mp3 m-230 what can i do ???
mostly, mp3 devices comes with a software.
if u have the software, and the usb dont recognize your mp3 device. most probably the problem is in you usb drive or usb connector.
Windows XP will not recognize my WD 250GB Harddrive
Just plug your USB HDD directly into your MBoard's USB port...
Computer doesn't recognize usb device...
do not use Front usb connector. put your device in backside of CPU usb port. it wil work fine.
Top SanDisk Computers & Internet Experts
Narseman
Sudeep Chatterjee
Sudeep Chatterjee
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
