Gain error. This will probably need an authorized Oce technician to re-calibrate the gain level. You could try with the calibration chart, but that probably won't work if the gain level is too far out of range.
IE Error Water inlet error. Cause : Correct water level (246) is not reached within 8 minutes after water is supplied or it does not reach the preset water level within 25 minutes Check to make sure the water valves are fully opened
Check/Repair
Ensure your taps supplying the washing machine are turned on.
>> Have a his newly bought ML-1640 used for about 50 prints.
>> The problem is that suddenly stuck a paper written nearly finished,
>> and the red light began to shine.
>> The red light Must visa green normally.
>> Tips on what the error is desired.
A part of a piece of paper is jammed somewhere along the "path" that the paper must travel. Take the printer to a certified technician, and have them repair it. Perhaps, the "warranty" will pay for the repairs, or will provide a replacement ???
We have a Canon IR 2016 J and in a beginning in the dispaly appears the message "Download Stanby" then after we replaced the PCB board appeared the message "System Error E354" what should we do to solve this problem, and if it is possible to send us the Service Manual with error codes for Canon IR 2016
