Texas Instruments TI-30XA Calculator Logo
Posted on Nov 18, 2007
Calulating Antilogs What key do I use when trying to calculate antilog?
  • fouroffive May 10, 2008
    antilog
  • Anonymous Oct 21, 2008
    what key do i use to figure antilog
A
Anonymous
Type in the number you want to find the -log for, then hit LOG and then hit the negative/positive key
A
Anonymous
A
Anonymous
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Oct 03, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
3106
Points
How do I use the antilog function on ti30xa?
Cannot calculate antilog value for negative numbers . Example: antilog(-5)
Make sure you use the (-) key to enter negative values, not the - key. For example, to calculate the common antilog of -5, press
SHIFT log (-) 5 =
To calculate the natural antilog of -5, press
SHIFT ln (-) 5 =
4helpful
I need help with the fx-115 ES on how to find what to hit to input calculation for antilog
Use the shifted function of the appropriate log key (log for common (base 10) log/antilog and ln for natural (base e) log/antilog). For example, to calculate the common antilog of 2, press SHIFT log 2 = and to calculate the natural antilog of 2, press SHIFT ln 2 =.
4helpful
WHERE IS ANTI.LOG ON MY CALCULATOR
The common (base-10) antilog is the shifted function of the "log" key on the third row of the keyboard, just above the "cos" key. The natural (base-e) antilog is the shifted function of the "ln" key just to the right of the "log" key. The two antilogs are marked "10^x" and "e^x", respectively.
4helpful
How do you use the -log function on the TI-30XA calculator? I downloaded the manual and there is no instruction for finding the -log of a number
Do you mean the antilog? For the common antilog, use the shifted function of the LOG key (marked 10^x). For the natural antilog, use the shifted function of the LN key (marked e^x).
For example, to calculate the common antilog of 0.5, press . 5 SHIFT [10^x] = and get about 3.16. To calculate the natural antilog of 0.5, press . 5 SHIFT [e^x] = and get about 1.65.
How to find antilogs on ti-30xIIs
press second then the log button.
thats the same as how you do log.
2helpful
2answers
How to find out antilog on scientific calculator
Antilog is a somewhat outdated terminology for the inverse function of the logarithm.
To calculate on your FX-115ES the base 2 antilog of 4, key in
Correct result is 16.
KK-82TL (double line display) scientific antilog how to find antilog
The natural antilog function is the shifted function of the natural log key (ln). The common antilog function is the shifted function of the common log key (log).
2helpful
Where is the antilog button? I need to input antilog and i dont know how.
The common antilog is the 2ND function of the common log (LOG) key, just to the left of the 7 key. The natural antilog is the 2ND function of the natural log (LN) key, just to the left of the 4 key.
3helpful
How to calculate the antilog please
The antilog is the inverse of the logarithm. Not too surprisingly, it's invoked as the 2ND shift of the appropriate log key.
For the common antilog, use the 10^x key (2ND LOG). For example, 2ND LOG 3 ENTER gives 1000 as the common antilog of 3.
For the natural antilog, use the e^x key (2ND LN). For example, 2ND LN 3 ENTER gives 20.08553692 as the natural antilog of 3.
Top Texas Instruments Office Equipment & Supplies Experts
Rommel Balcita
Paul Bade
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
