Hi,i have a epsom cx6600 i have had it for 2 years. changed my ink yesterday all was fine,then i thought i would clean my heads.i got an error message,Parts inside your printer are at the end of their service life.but it was printing fine before is there anything i can do to disable this warning,i have tried pressing all the buttons but nothing will work.cath I have a Stylus C67 and also have the "parts of your printer have reached the end of the service life" I tried to down load the software to reset. Not sure how it eorks but it has not solved the issue after much playing....... Also tried the ten second button holding down, No Joy, then tried pressing all the buttons together and all at different times. No Joy. Cant find the manual to change the ink tray. Other than throwing the printer out the window, has any one got any other suggestions. Or shall i make the arangement for the untimley passing of a stylus C67..... ????? Thanks
Is this going to end up in landfill because Epson wont tell how to fix. they told me buy a new one I did Canon
Make those arragemnets, it needs its waste ink pads replaced and ink clean counter reset via Epson Service software (Eagle)
If you just rest counter you are likely to have ink running loose into printer, there are 8 seperate ink pads in these none of them easy to replace, machine need to be fully stripped to do so.
These macnes count how many cleans they do and stop when figure that epson estimate ink pads are full is reached. It is more ecomical to replace inkjets than to fix, buy a new one with gen inks warranty for same price as repair bill.
