Sony BRAVIA KDL-40W600B 40" 1080p LED-LCD TV - 16:9 - HDTV 1080p ATSC - 178A / 178A - 1920 x 1080 - Dolby Digital Plus, Dolby Pulse, Surround Sound - 4 x HDMI - USB - Ethernet - Wireless LAN - DLNA Certified - PC Streaming - Internet Access - Media Player Logo
A
Anonymous Posted on Jan 31, 2016
Need the TV code for U-Verse remote - Sony BRAVIA KDL-40W600B 40" 1080p LED-LCD TV - 16:9 - HDTV 1080p ATSC - 178A / 178A - 1920 x 1080 - Dolby Digital Plus, Dolby Pulse, Surround Sound - 4 x HDMI - USB - Ethernet - Wireless LAN - DLNA Certified - PC Streaming - Internet Access - Media Player
Martin M
Level 1:
New Friend:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Jan 31, 2016
Martin M
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
9
Questions
0
Helped
1505
Points
17
1helpful
I have an ilo tv and it is stuck on a blue screen when it is turn on and says composite in the top corner. i've purchased a new universal remote that has some ilo codes but none worked. when i do a...
Hello
It is very difficut to get a substitute remote control for your ILO TV. Anyway try these codes with your present remote control. These codes are with AT&T U-verse remote for ILO TV. The codes are:
1412, 1435, 1436
If these codes does not work with your ILO TV, buy one AT&T U-VERSE remote control. It will match for it. OK.
1helpful
I have ATT u-verse remote, but I don't have code to control new Hannspree 32inch lcd tv. Can you help?
I also had this problem. I talked to an AT&T technical support guy over the phone yesterday, and he told me some weird instructions. The TV was responsive to the controller but we couldn't get it to work. About an hour ago I called Hannspree technical support and they told me codes to control my AT&T receiver with their remote. I just tried the codes for my AT&T U-verse remote, just to see if they would work anyhow, AND THEY DID! Unfortunately, the codes will control the TV entirely, except turning it on.... (it does turn it off though) If these codes are of any use to you, they are: 1004 and 1018 try the first one, and if doesn't work, try the second one. If you are new to the AT&T U-verse world, these are the instructions: *Turn on your TV first 1)Hold the TV button on the AT&T remote 2)While holding, hold the OK button 3)Now release both of them 4)All the mode buttons while now flash twice (You will now have 6 seconds to do step 5, if not they will do a long flash, indicating to start over) 5)Now, quickly, type in the combination (in this case, 1004, or 1018) 6)The TV button will flash 3 times if it works, or a long flash if it doesn't 7)Now point the remote to the TV and press Power. If it turns off, IT WORKED! *Remember, these codes are the only codes I know of and they took forever to find, and they aren't supposed to work with the AT&T U-verse remote, but they did. The only defect is you can't turn ON the TV with the AT&T U-verse remote, but you can do everything else (YOU CAN TURN IT OFF)
Hope this helps!!!!
1helpful
Need the isignia remote codes for at&t u-verse
You can find remote control codes for your TV here, click the Support tab. If the codes listed don't work, there is also a listing of compatible brand codes that you can try.
1helpful
Code needed for Memorex MLT 3221 HDTV To work with AT&T U Verse
Try 1431 - it's a Poloroid code since some Memorex tvs are similar
8helpful
5answers
U-Verse remote for Digital Lifestyle
I use my Directv remote to change the channel. What you have to do is go the your direct tv remote go to setup then go to remote then look for tv brand Citizen then follow the direction the menu tells you to do. It works fine. You can use Tv Brand Citizen, Concerto, Luxman They work with any u-verse remote 4 digit code 0056 5 digit code 10056
2helpful
2answers
Need remote control code for ATT U-verse
Use the code search method. MANY TV's are branded from a few suppliers. Emerson has about 50 codes!
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
