Sanyo DS31520 31" TV Logo
Jack Brisendine Posted on Nov 29, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where is the reset button
Won,t come on
Claude Kayser
Level 3:
Top Expert:
  • Sanyo Master 9,098 Answers
  • Posted on Nov 29, 2015
Claude Kayser
Sanyo Master
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5165422
Points
28437
Sanyo Service Menu - Factory-Reset.com
factory-reset.com/wiki/Sanyo_Service_Menu
Jump to Sanyo TV Service Menu Method 2 - Unplug the power cable. Press and hold the {VOL -} button on the TV while plugging the power cable back ...
Sanyo TV reset button location? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jul 27, 2007 - Does anyone know where to find the reset button on a 32" Sanyo TV? The thing is just totally dead and I am thinking maybe if I push the reset it ... I have a Sanyo TV, I accidentally hit the reset button twice. I ...
Aug 6, 2012
36 inch sanyo tv won't change off video 2?
Apr 17, 2010
I accidentally hit the 'reset' button the remote of my sanyo tv ...
Jan 6, 2010
Sanyo DS32224 TV Problem!!?
May 21, 2009
More results from answers.yahoo.com
2answers
Fully charged. Why doesn't it turn on?
Ruby, try pressing and holding on button or you will have to reset.
Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Reset Kindle Fire When it Won Turn on or Charge
My kindle won turn on
My kindle won turn on Is it the battery Kindle Fire HD
Amazon Kindle Won Charge Quick Fixes
Wireless LAN button won't switch off.
Most Netgear routers have a recessed button on the back or bottom panel, marked "Reset" or "Restore Factory Settings". Because the button is recessed, you will require a thin tool to press it. Most people use a straightened paperclip.
  1. Power up the router, and wait for it to complete booting up, typically about one minute.
  2. Press the Reset or Restore Factory Settings button until the test or power led starts blinking. This takes about 20 seconds. Release the button.
  3. Wait for the router to reboot.
  4. Log in with the default password. If the reset was not successful, try these additional steps AFTER the router has finished rebooting.
  5. Unplug the router's power.
  6. Press and hold the Reset button. While the button is held down, reconnect router's power.
  7. Continue to hold the reset button for 20 seconds after reconnecting the power.
  8. Wait for the router to reboot.
  9. Log in with the default password.
Microwave won't start when pressing the start botton
call Chas&son,s appliance repair at 579-379-0993 and they will come out the same day no less okay
1helpful
2answers
My straight talk LGL55C powers up and goes to the blue tracphone blue screen and won't power off with power button or anything
Take the Battery out.
Place it back in.
Press and hold the Vol down : Home : Power buttons simultaneously for 10 sec.
Using the volume buttons navigate to the reset to factory settings option.
press select (left of home on L55C).
Confirm to reset.
Select to reboot.
You should be good.
Oct 30, 2012 • Cell Phones
My password won't work?...and it won't open...what would i do ??.the reset button also wodl'nt work?/
if the reset button wont work better to replace the router. But before replacing try the following steps first to reset your router.
Step 1: Plug the power of your router wait until the lights are fully initialized.
Step2 : Reset your router by pressing the reset button or hole with atleast 5-10secs.
Step3: Open a browser (ei, IE Mozilla or Google Chrome etc.) and type the specified IP address on the address bar.
Step4 Then type the username : Admin password : 1234 or leave it blank.
Hope it helps.
21helpful
3answers
My coby kyros won't turn on, won't charge, no lights are coming on
Mine does that to but all I ever do it just hit the reset button on the back and it turns back on.
I need to reset my password on my rca HD52W55
Hello
If your RCA tv has locked or you want to reset your password you can opt any one of the followinf option to unlock it without any passcode nd can reset it after.
Most RCA TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
  1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won
Protron dvd won`t start
try to ask your question to the problem section you will have more chance
1helpful
Ink cartridge full but won´t print
This might need to be reset.
Here' how...just follow the instructions..
moz-screenshot.pngThere's two ways to reset it
First: Soft Reset
1. Open front cover.
2. Hold down button located under LED's until all LED's are lit.
3. Release button and make sure drum LED is off, then
4. Close cover
Second: Factory Reset
1. Turn the printer off.
2. Hold in the circular button on the front panel of the printer.
3. Turn the printer back on.
4. When the DRUM light is lit by itself let go of the button.
5. Hold in the circular button on the front panel again.
6. Once the Alarm light comes on, let go of the button.
This will perform a factory reset on the printer.
I hope that's everything you want.
Please accept this answer if this will help you.
Thank you for using Fixya.
Top Sanyo Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
