Xerox WorkCentre M20i All-In-One Laser Printer Logo
Posted on Jul 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Scanner locked - Xerox WorkCentre M20i All-In-One Laser Printer
Anonymous
Level 3:
President:
  • Master 2,072 Answers
  • Posted on Jul 15, 2009
Anonymous
Master
Level 3:
President:
Answers
2072
Questions
0
Helped
1124784
Points
5836
Look on the bottom side of the scanner.
There is one and only one green item on the bottom of the scanner. That is the scanner latch.
Turn the machine off, push the latch in toward the back of the machine, then pull it out toward ourself until you hear and feel it snap.
That should take care of your problem.
I am looking for scanner locked?
All questions need 'make model (what it is)'. We only have 'Scanner'. And then a clear question, what does 'scanner locked' mean? You are looking to lock it?
scanner locked printer
Microsoft Community
https://answers.microsoft.com > windows > forum > all
Jun 19, 2023 - A Scanner Locked error is displayed on the printer, when the scanner head is unable to move. Do the following to try and resolve the error:.
HP Officejet 9100 All-in-One Series - "SCANNER LOCKED. ...
HP Support
https://support.hp.com > in-en > document
This message is displayed if the scanner is locked or the scanner module is not seated correctly. ... Enter a topic to search our knowledge library. Enter a topic .
Where is the scanner lock button of kyocera 4012i? to solve C3100 it says check the scanner lock
The scanner lock button on the Kyocera TASKalfa 4012i is located on the left-hand side of the machine, towards the back of the scanner unit. It is a small lever that can be turned to lock or unlock the scanner unit.
To solve the C3100 error on the Kyocera TASKalfa 4012i, you should first check to make sure that the scanner lock is in the unlocked position. If the scanner lock is already unlocked, the issue may be related to the scanner motor or the scanner home position sensor.
In this case, it is recommended that you contact Kyocera technical support or a certified Kyocera service technician for assistance in resolving the issue.
5helpful
Hi I have just purchased a Samsung CLX- 3185 Colour printer, scanner and copier and the screen states ' Scanner Locked'
The scanner may have a locking lever that locks the scanner head so you can transport it without damaging the scanner head.
Locate the locking lever and unlock the scanner head.
4helpful
Scanner locked
Check your green scanner lock which is under the scanner area right in that area where your copies comes out of the machine. This is the most common cause of the "scanner locked" condition. The lock gets accidentally engaged as it is located right where you reach in to get your copies.
If the lock is not the problem then you may have a scanner drive issue.
Good Luck and Thank You for using Fixya.
SCX 4216F Scanner LOCK
It can also be the ribbon cable connecting the scanner to the formatter board. Check that it is connected properly.
1helpful
Error message says: Scanner is locked, Computer cannot communicate with scanner.
Have you checked the obvious? The scanner lock switch is located on the bottom of the scanner back right corner. --Ted
Scanner is locked
Pls try locking and unlocking when power is off. S. Mohan
2helpful
2answers
Scanner locked - unlock scanner
To unlock a scanner open it where you would put cartridges in and look for a red or green colored tab hanging down. There should be a little picture of a padlock. You can switch it from lock to unlock. It's kept locked to protect the scanner during shipping.
Hope this is helpful...
5helpful
3answers
3helpful
Dell A940 - Unlock Scanner then press power
See
http://support.dell.com/support/edocs/systems/a940/a940en1.pdf
Page iv identifies the location of the scanner lock
Page 44 contains the following
• You unlock the scanner bed. For help locating the scanner lock, see the picture of the printer on page iv.
Page 51 contains
Unlock Scanner message
The scanner is locked. To unlock it:
1 Press Power to turn the printer off.
2 Use both hands to lift the printer (scanner unit) until the scanner support
holds it open.
To the left and beside the scanner support is the scanner lock. For help, see
page iv.
3 Pull the scanner lock toward you to unlock the scanner.
4 Using both hands, lift the printer (scanner unit).
5 Push and hold the scanner support back.
6 Lower the printer (scanner unit) until it is completely closed.
7 Press Power to turn the printer back on.
Top Xerox Office Equipment & Supplies Experts
Sudeep Chatterjee
Sudeep Chatterjee
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
