Washing Machines Logo
Jen Smith Posted on Sep 06, 2015
BFLW75 Baumatic Front Loading Washine Machine Displaying E62 code. How do you fix it?
Washing towels. Yes the water temp was 95. Came in to find the error code displayed. Machine stopped. Will not reset. Machine has been off overnight and still has error code. Machine bought August 2014
4 Related Answers
Anonymous
  • 209 Answers
  • Posted on Sep 09, 2007
SOURCE: Indesit front loading washing machine error code
i am a recently retired engineer of 20 years, but this sounds like (based on the info given) a heater element fault, after the machine fills up and agitates a few times the heater should start, check the heater for open circuit, replace if needed, of course it just could be a wire off? if i have helped rate me please
Anonymous
  • 4 Answers
  • Posted on Apr 17, 2009
SOURCE: Hotpoint WF860 Washing Machine displaying error F-65
there is no F65, perhaps it's F05 which means it will not empty water (not oumping out). Should av gone to specsavers !
Anonymous
  • 15935 Answers
  • Posted on Sep 18, 2010
SOURCE: My front loading Kenmore is stopping in the middle of its cycle.
"F21" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
mbarre
  • 937 Answers
  • Posted on Jan 16, 2015
SOURCE: my lg washing machine front loader display IE error code and i have check the hole clean the filter valve and check water pressure still displaying IE error code
THis may help:
Top Washing Machines Experts
AskDyson
AskDyson
ADMIN Andrew
ADMIN Andrew
