Hotpoint Ultima WF865 Front Load Washer Logo
Posted on Jul 12, 2009
F12 code what is it - Hotpoint Ultima WF865 Front Load Washer
Anonymous
Level 1:
Problem Solver:
  • Contributor 13 Answers
  • Posted on Jul 17, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
13
Questions
5
Helped
3766
Points
39
F12 is no communication between cards,best to call an engineer
F12 error flashing on the display
Keyword Ranking Analysis for ARISTON OVEN FAULT ...
www.webstatschecker.net/stats/keyword/ariston_oven_fault_code_f12
Keyword Ranking Analysis for ARISTON OVEN FAULT CODE F12 ... fixya.com.Ariston Technologies Ariston AWD120WH - "F12 error code" issues
F12 Bike Computer code for a fat tire bike
https://bugtingpreltab.files.wordpress.com/2015/10/bell-f12-bike-computer-manual.pdf
If you need further help, reach me via phone at https://www.6ya.com/expert/cynthia_0eebb7da17b33b5e
F12 error code
F12 SPECIFIC FOR LVB2000 INDESIT EVOLUTION / DIALOGIC.
F12: Lack of Display card-Main Card Communication
1. Check the effectiveness of contacts on CNC Connector Card
2. Overhaul 8-way connector on Display card
3. Check continuity of CNC-CN 8 way connector
4. Replace Main Card
5. Replace Display Card
Dado
2helpful
F12 error code
Also here is a list of He2 error codes http://www.applianceblog.com/mainforums/sears-kenmore/10283-he2-error-codes.html
I think the error code you are actually getting maybe an F21 due to there is no listing for F12. use this kink to put the unit into diagnostics and run the diagnostic menu which will give you your exact error code as well. I await your reply
Thank you
Rick
5helpful
Hotpoint WF860 1600 spin machine keeps flashing F12. How can I solve it please???
Hi
The code F12 means the following:
F12 - No mixed fill. It is likely that the water is not turned on at the taps
Also Error code F12 is indicating a communications error between cards; Error code F12 is indicating a communications error between cards, this can be caused by one of several things. A problem with bad connections, if you can remove and then replace the plug on connectors, check for loose or chafed wires to motor, they can chafe due to tightness of wires, particularly down to the motor.
It is an electrical problem as opposed to a mechanical one.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
1helpful
F12 code
Ive looked thru all my manuals and can not find a f12 error code anywhere even looked on-line all you can do is call Whirlpool in the morning and speaking with there customer service reps to find out what it is sorry for the troubles....
2helpful
Hotpoint ultima washing machine has error code f-12
F12 - No mixed fill. It is likely that the water is not turned on at the taps.
here is a link to all hotpoint error codes:
http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
If this helps please rate me
5helpful
F12 code problem with indesit we16
F12 means no communicastion between boards.
Check all connections and wiring between the boards.
Good luck
53helpful
3answers
F12 Error
what is F12 error code on a siemans wxlp1400 and how do i cure the fault, cheers
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
