Solution for error code 301
The IBM error 301 POST code means the keyboard is not responding correctly.
You could have a stuck key, or the keyboard cable is faulty and not making proper electrical contact.
You could have a faulty keyboard controller.
You may have a faulty keyboard which may had some fluid spilt on the keys.
Try clean and reconnect the keyboard cable.
If this doesn't work try connecting an USB keyboard and see if this keyboard functions correctly.
If none of these work you have a motherboard problem. The Thinkpad 600 is a very old laptop and it would not be worth fixing. I suggest putting your money towards a new laptop.
Anytime the Error 301 messages appear on your computer, it is due to corrupt or damaged system files.
If you do not fix this error immediately, it can lead to additional system issues, blue screens and hardware problems.
Frozen programs, installer errors, random shutdowns, system freezing and sluggish computer performance are common symptoms of the Error 301.
Fortunately, you can fix the Error 301 with features native to your computer.
Click "Start" and then "Computer." Right-click "C" and select "Properties."
Select the "Tools" tab and click "Check now." Select "Continue" if the User Account Control prompt displays.
Select the "Automatically Fix File System Errors" option and click "Start." Agree to reschedule the check for the next system restart.
Reboot your system.
Allow the check disk to detect and repair all Error 301 issues.
you should have no input while chkdsk utility is in progress any input might further damage your computer it might take some depending on the size of the disk be patient.
Hope this helps
