Computers & Internet Logo
A
Anonymous Posted on Mar 14, 2015
Compatible memory card - Kingston Computers & Internet
Mike M
Level 3:
  • Kingston Master 3,349 Answers
  • Posted on Mar 14, 2015
 Mike M
Kingston Master
Level 3:
Answers
3349
Questions
0
Helped
704741
Points
16707
Nikon B500 camera. I put a new memory card in my Nikon B500 and the camera says 'card not present'.
Is it this type of card?
The B500 is compatible with SDHC and SDXC cards. That means you can use cards from 4GB all the way to the largest cards currently available. (at that time 128GB)
And is it less than 128GB?
Your Nikon Coolpix B500 Digital Camera is compatible with 16GB, 32GB, 64GB and 128GB SD, SDHC and SDXC memory cards.
https://www.google.com/search?q=nikon+coolpix+b500+compatible+memory+card
I tried to use a 16GB PNYcard in my picture fram and it would not work. It said "No Card" on the screen. What's the answer?
If your picture frame is not recognizing the 16GB PNY card and displaying a "No Card" message, there could be several reasons for this issue:
  1. Compatibility: Some picture frames may have limitations on the size or type of memory card they can accept. Ensure that the picture frame is compatible with SDHC or SDXC cards, as these are the types commonly used for higher-capacity cards like 16GB.
  2. File System: Check if the memory card is formatted in a compatible file system such as FAT32 or exFAT. Some picture frames may not recognize cards formatted in other file systems. You may need to format the card using a compatible file system on your computer before using it in the picture frame.
  3. Card Reader Slot: Ensure that the memory card is inserted correctly into the card reader slot of the picture frame. Sometimes, improper insertion can prevent the device from detecting the card.
  4. Card Compatibility: While SDHC and SDXC cards are generally backward-compatible with devices that support SD cards, some older picture frames may have limited compatibility with higher-capacity SD cards. Try using a lower-capacity SD card (e.g., 2GB or 4GB) to see if the picture frame recognizes it.
  5. Faulty Card or Picture Frame: If none of the above solutions work, there may be an issue with either the memory card or the picture frame itself. Try using the memory card in a different device to check if it's functioning correctly. Similarly, try using a different memory card in the picture frame to see if it's able to recognize it. If the problem persists, there may be a hardware issue with either the card or the picture frame, and you may need to contact the manufacturer for assistance or consider replacing the faulty component.
By following these troubleshooting steps, you should be able to determine the cause of the issue and resolve it accordingly.
Nov 22, 2016 • Photography
2helpful
3answers
What is the maximum size sd card (Gigabites)?
speed class choices.
about compatibility with host devices before choosing your card, it is important that you understand how to use your memory card to it greatest ability. sdxc memory cards and devices (digital cameras, video cameras, laptops, etc.) are now available. learn how to use your new sdxc memory card to optimize its performance.
confirm compatibility before inserting your sdxc memory card, confirm the device is compatible with the sdxc standard by locating an sdxc logo on the device or referring to the device's user manual or manufacturer information.
understanding backwards compatibility
  • sdxc memory cards must only be used with sdxc devices.
  • sdxc devices can use sd memory cards, sdhc memory cards and sdxc memory cards.
  • sdhc memory cards can be used with sdhc devices and sdxc devices.
  • sdhc devices can use both sd memory cards and sdhc memory cards.
  • sd devices can only use sd memory cards.
http://www.tomshardware.com/charts/memory-cards,39.html
the link above has several chart on sd cards.
Jan 20, 2015 • Cameras
1helpful
I have problems with card reader is not compatible with w in 8.1 pro
Hello
Probably you need to download Driver for it to use.
Hope this Helped
I insert memory card in to my touch t-mobile but not supported say format memory card what shall i do right now?
Hi Teddy.
Regarding the issue you have with the memory card & the error message showing on the phone. It could be that the memory card you're using is not compatible with the phone model that you have.
Every phone has it's own maximum size of the memory card compatible to it.
E.x. A phone could only support up to 2Gb, but your memory card size is 4Gb.
You could contact your phone manufacturer & ask the maximum size of the memory card allowed for your phone.
If your memory card is compatible with your phone, you could just proceed in formatting the memory card on your phone.
**WARNING**
Formatting the memory card will erase everything saved in it.
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
2answers
My Kodak DX4900 lense will not retract when I turn the camera off. If I hit it, then it retracts. It has no problem coming out when I turn it on, but won't retract when I turn it off unless I hit it....
This is a list of the error codes, obviously some aren't of much help but ...
E1 The memory card is not compatible with the DC50 Zoom Camera. Use a compatible card. E10 Take the camera to your dealer for service. E11 Take the camera to your dealer for service. E12 Take the camera to your dealer for service. E13 Take the camera to your dealer for service. E14 Take the camera to your dealer for service. E15 Take the camera to your dealer for service. E16 Take the camera to your dealer for service. E17 Take the camera to your dealer for service. E20 Reseat the memory card.
or
Replace the memory card with a known good card.
or
Take the camera to your dealer for service. E21 Confirm that the memory card is compatible with the camera.
or
or
or
Take the camera to your dealer for service. E22 Reseat the memory card.
or
or
Take the camera to your dealer for service. E23 Confirm that the memory card is compatible with the camera.
or
Take the camera to your dealer for service. E24 Confirm that the memory card is compatible with the camera.
or
or
Take the camera to your dealer for service. E25 Confirm that the memory card is compatible with the camera.
or
or
4gb sandisk sdhc card
I think the C330 is not compatible with the SDHC cards.
The spec for the SD card format is going to 2GB but the Kodak C330 not compatible with 2 GB SD memory cards.
Click
But try an firmware upgrade.
Why download firmware version 1.07?
This firmware version improves memory card compatibility and provides general performance updates.
KODAK EASYSHARE C330 Zoom Digital Camera Firmware
1helpful
2answers
Memory card compatibility
Yes, SDHC memory cards are compatible with the Canon Powershot A700, so that means you can use card with capacities over 2GB. You can also see the manual to verify this, Canon Powershot A700 Manual. On page 8, it says that SDHC memory cards are compatible.
2helpful
N73 problem
Use only miniSD cards approved by Nokia for use with this device. Nokia utilizes the approved industry standards for memory cards but not all other brands may function correctly or be fully compatible with this device.
Use only compatible miniSD cards with this device. Other memory cards, such as Reduced Size MultiMediaCards, do not fit in the memory card slot and are not compatible with this device. Using an incompatible memory card may damage the memory card as well as the device, and data stored on the incompatible card may be corrupted.
Press menu and select Tools > Memory. You can use a compatible miniSD card as extra storage space and for backing up the information in the device memory.
To back up information from the device memory to a compatible memory card, select Options > Backup phone mem.
To restore information from the compatible memory card to the device memory, select Options > Restore from card.
To eject the memory card, press , and select Remove mem. card.
Important: Do not remove the memory card in the middle of an operation when the card is being accessed.
Removing the card in the middle of an operation may damage the memory card as well as the device, and data stored on the card may be corrupted.
"I used to be apathetic, but somehow I just lost interest..."
Nokia N70 wont acknowledge memory card?
Note: This device uses a Reduced Size Dual Voltage
(1.8/3V) MultiMediaCard (RS-MMC). To ensure
interoperability, use only dual voltage RS-MMCs. Check
the compatibility of an RS-MMC with its manufacturer or
provider.
Use only compatible Reduced Size MultiMediaCards
(RS-MMC) with this device. Other memory cards, such as
Secure Digital (SD) cards, do not fit in the memory card
You cannot use the memory
card if the door of the
memory card slot is open.
Format a memory card
When a memory card is reformatted, all data on the card
is permanently lost.
Some memory cards are supplied preformatted and others
require formatting. Consult your retailer to find out if you
must format the memory card before you can use it.
To format a memory card, select Options > Format mem.
card
. Select Yes to confirm. When formatting is complete,
enter a name for the memory card, and select OK.
Top Kingston Computers & Internet Experts
Sudeep Chatterjee
Sudeep Chatterjee
Narseman
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
