Ovens Logo
Posted on Jul 09, 2009
Error message I have an error message of ''F5'' after I tried to activate the self cleaning I just want to know how to fix the oven so the self cleaning function works
1 Related Answer
Anonymous
  • 15935 Answers
  • Posted on Oct 01, 2010
SOURCE: E1 F5 error message when try to activate the self clean
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Top Ovens Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
john h
Are you an Oven Expert? Answer questions, earn points and help others
