Computers & Internet Logo
A
Anonymous Posted on Feb 23, 2015
How to connect 2 cd-roms to motheroard
BD711
Glenn Seaton
Level 1:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Feb 26, 2015
Glenn Seaton
Contributor
Level 1:
Problem Solver:
Answers
8
Questions
0
Helped
1493
Points
11
If they use the wide ribbon cable, you need the cables with two connectors. Then set on drive to master and one to slave, or set both to CS - for cable select. When you restart the computer, the OS will do the rest.
When u put a new cd rom in where does the wire go 2
It depends on the CD-ROM you will install. But by default the cd/dvd-rom of this computer is connected via SATA connector and is plugged into one of the 4 SATA ports in the motherboard.
Thank you for visiting FixYa!
Hoew to install CD Drive
You want to install a CD Drive. Ok you are Following these steps....
  1. Unplug the power cable from your power supply and open your Computer case.
  2. Determine which drive bay you are going to install a CD-ROM into. You should pick on of the uppermost drive bays
  3. Before you install a CD-ROM, make sure you have the proper jumper settings. You are only installing a single CD-ROM, set the jumpers as MASTER. The jumper settings are different for each CD-ROM drive, so consult your owner's manual so you know which pins to cover up.
  4. Once you have the jumpers set, install your CD-ROM in the computer's case. How you secure the CD-ROM in one of the uppermost drive bays depends on your case. Some CD-ROM drives have to be screwed into the drive bay.
  5. Connect the power to the back of the CD-ROM drive, then connect the ribbon cable to the back of the CD-ROM drive. Your ribbon cable has three connectors, one in the middle and one on each end. The middle connector is a SLAVE connector that is used if you would install an additional CD-ROM or DVD-ROM drive.
  6. Connect one of the end connectors to the CD-ROM drive, and connect the other end connector to the appropriate spot on your motherboard. Note, hard drives and CD-ROM drives have the same style of connector on the motherboard. You want to connect your CD-ROM drive to the motherboard slot that isn't red or is the highest numbered of all the IDE slots.
  7. Power on your computer after you plug it in. Your computer should recognize the new CD-ROM. If it doesn't, go into your motherboards BIOS and search around for the IDE channels, they need to be set to automatically.
Thank U
CD ROM DOES NOT APPEARS ON MY DESKTOP. WHEN I OPENS MY COMPUTER THERE`S DOES NOT APPEARS THE CD-ROM`S ICON.
1.check your connections of CD Rom inside the Cpu box, if any loose contacts there, then your cd rom wont appears on the computer,
2. change the data cable
3. connect different power socket to the cd rom
4. goto Bios setup, press Del key or F2 key to enter the Bios setup
5. check your cd to detect
6. save it and restart your computer
1helpful
Intel 845epi board not booting
Please go through the following option :
1) Check the master and slave jumper settings of hard disk and CD-ROM. Hard disk jumper setting should be Master and CD-ROM should be slave.
2) Check the cable of hard disk and CD-ROM.
3) Use different power supply which should be in good condition and than attach your hard disk and CD-ROM.
2answers
I can't boot from external usb dvd/cd drive
please try to remove the connection between motherboard and vd/dvd drive.
then perform the previous steps.
When i set cd rom as my first boot device and if i restart my pc its not booting through cd(for win98 installation)
1, Check if your cd-rom is reading properly, You can do that by connecting the cd-rom to another computer
2. Hope it's the first point because if not, than it's not the cd-rom the problem but the main comptroller on the motherboard. If this is the case then the only alternative is replacing the motherboard.
Mobo only one ide connection socket for HDD & CD-Rom
yes you can add both your HDD and CD-ROM Drive with the same IDE, get a IDE data interface cable (BUS) atleast three connection point. Add 1 to mobo, second to HDD and top 1 one to CD-ROM drive. Just connect and dun wrry m sure it will work....so............:))
If any problem just Ask me
Thanks
Iqbal
My cd-rom has trouble reading disks
1.some times this happened the loose connection of the IDE cable,and power cable.
2.so disconnect the IDE and power cables and then connect again.
if not fix
3. exchange the IDE cable of hard disc.
4.if no result,the lens of CD Rom has damaged, you will be have to buy a new CD rom....
thanks!
Top Abit Computers & Internet Experts
Rommel Balcita
Sudeep Chatterjee
Sudeep Chatterjee
Grand Canyon Tech
Grand Canyon Tech
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
