Tablets & eReaders Logo
J
Julie Blake Posted on Feb 16, 2015
Why is there not enough storage when the device is apparently supposed to have 8GB of it?
Our 8GB Kobo broke and we got this Blaupunkt for the kids. Trying to download the apps they had before is impossible because there is not enough room. We can only get less than half of the apps they used used to have. Where is the 8GB storage it's supposed to have?
Med Moncef
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 3 Answers
  • Posted on Feb 16, 2015
Med Moncef
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
Questions
0
Helped
1441
Points
8
Error message 075-210 relates to the lift motor in the tray mechanism. The description from the manual states "Tray 5 Lift Up Sensor does not turn ON a spec time after Tray 5 starts lifting up. "
This is becoming a common problem as the machines gets older and is a simple fix.
Inside the tray 5 there is drive motor with lots of gears, it is the smallest gear that is slipping on the drive motor, this means the drive mechanism doesn't have enough power to lift the paper tray to the up position, so the error will appear.
The simple fix is to remove the small gear and put some epoxy resin inside it and put it back on the shaft, this seems to fix 95% of these problems. Just be careful not to get any glue on the surrounding gears or the driver motor itself. See the image attached to see where the small gear is located inside the drive mechanism.
Why is there not enough storage when the device is - 25435368-clhuw2bxldb4w0xl3yasewsm-4-0.jpg
How do I download apps onto this device?
The default on most tablets is to install apps to internal storage so the SD card does no good by itself. You can go into Settings>Applications and change the location for each app to the SD card. Likewise anything else you put on a tablet, particularly photos and videos get stored in internal storage. If you have taken a lot of photos and videos they can fill up your storage quickly. You can change this in the Camera app by tapping the settings icon and changing the storage option to SD card. You will still need to actually move existing photos and videos to the SD card manually or copy them to external storage and delete them. I would also change the image and video resolution in Camera settings to 640x480. This is plenty good enough for pictures you just want to look at on the device or share online.
Kobo plugged into computer but nothing happens when I press connect
Do you have the proper device driver installed on the computer?
:Other info I found online, but have not looked into:
Open the Hardware and Devices troubleshooter
http://windows.microsoft.com/en-us/windows7/Open-the-Hardware-and-Devices-troubleshooter
In addition you can also check if the device manufacturer have driver for the device.
For additional help, please see:
Kobo Help Forums/Frequently Asked Questions - Kobo eReader
http://kobo.zendesk.com/forums/165796-frequently-asked-questions-kobo-ereader
Need help with your Kobo eReader?
http://koboereader.com/FAQ
My kobo arc 7 screen is not responding to touches. Can it be reset?
1. Turn the power off and pull the battery out and reinsert it.
2. Hold the Volume Down button.
3. Then press and release the Power button.
4. Wait a minute,the menu appears that allows for Fastbook, Recovery, Clear Storage, and Simlock.
5. Ok,press the Volume Down button to choose Clear Storage.
6. Next,press and release the Power button,Wait for the Kobo Arc to restart.
7. You will see the two options: Volume Up for YES and Volume Down for NO.
8. If you choose YES, all data will be deleted from your Kobo Arc and including third-party applications.
9. The Kobo Arc will reboot to its original data.
10. This time you can restore your backed up data to your phone.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/michael_e0539de310ea5ad7
1helpful
Kobo Glo ereader
try to reset it..... how to reset device would be written in you users manual
I have a problem with my literati ereader its functioning well until I upgraded it last week now it wont recognize my sd card..I tried others it just wont recognize it. then I tried putting some of my...
Solution: Use the Literati USB connection and the following steps
1. Plug the eReader into a charger
2. Download v2.0 of the Literati or Lookbook firmware from - http://download.kobobooks.com/firmwares/merchsource/2-0/KoboRoot.tgz , and save the file somewhere you will remember
  • NOTE: Some browsers will download the file and rename it to KoboRoot.tar. The upgrade will not work with the .tar extension. If this happened with your download, please rename the downloaded file to KoboRoot.tgz
3. Keeping the charger connected, connect the Literati or Lookbook to your computer through the provided USB cable
4. The eReader will appear on your computer as a mass storage device
ON A MAC:
1. Open mass storage device in Finder
2 . Click GO from the top menu
3. Click Go to folder
4. Type in .kobo (include the period).
5. .kobo folder will open
6. Transfer the KoboRoot.tgz file you downloaded to the .kobo folder
7. Once the file has transferred, safely eject the eReader
8. Turn off the eReader
9. Turn on the eReader
10. The eReader will take up to 10 minutes to start up, please be patient and do not reset or power off the eReader in any way.
11. Once the eReader restarts, it will have the latest version (v2.0) installed. You can verify this by pressing the menu button, selecting Settings and looking at the Version number.
ON A PC:
1. Open mass storage device in Windows Explorer
2. Ensure hidden folders are visible (different for different Windows versions)
XP: Go to My Computer > Tools menu > Folder Options > View Tab > Advanced Settings > Hidden Files and Folders > Show hidden files and folders. Press OK all the way out.
Vista and Windows 7: Start > Control Panel > Folder Options > View Tab > Click Show Hidden files and folders > OK
3. Open .kobo folder in the mass storage window
4. Transfer the KoboRoot.tgz file you downloaded to the .kobo folder
5. Once file has transferred, safely eject the eReader
6. Turn the eReader off
7. Turn the eReader on
8. The eReader will take up to 10 minutes to start up, please be patient and do not reset or power off the eReader in any way.
9. Once the eReader restarts, it will have the latest version (v2.0) installed. You can verify this by pressing the menu button, selecting Settings and looking at the Version number.
Top Tablets & eReaders Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
