Kocaso MID M9100 9 Dual Camera Android 4.0 ICSOS 1.2Ghz Capacitive Multi-Touch 8GB 512RAM Tablet PC-Purple Logo
a
anthony wells Posted on Feb 04, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can I reset my pattern lock screen I for got it
Reset button
Mike
Level 2:
Sergeant:
  • Expert 435 Answers
  • Posted on Feb 10, 2015
 Mike
Expert
Level 2:
Sergeant:
Answers
435
Questions
0
Helped
91793
Points
601
If you can get into "Settings" its in there to change it
How can I reset my tablet?
    1. Here's how to execute a factory reset:
      1. Turn your tablet off and remove the SD card, if there is one.
      2. Press and hold the combinations below until you feel the device vibrate: Power button + Volume up and down (if there is a physical Home button) Power button + Volume up + Home button (If there is a physical Home button)
      Forgot your tablet's password? - TechAdvisory.org
      www.techadvisory.org/2013/03/forgot-your-tablets-password/
    Feedback
  1. Forgotten Pattern, PIN or Password on an Android device
    acer.custhelp.com/.../forgotten-pattern,-pin-or-password-on-an-android-...
    What can I do if I set a Pattern, PIN, or Password on my Lock screen but forgot it? ...If you do not have Android Device Manager installed, the tablet must be reset ...
My daughter got locked out her digiland tablet and dont have a manuel on how to reset because her email she used to set up her tablet is not working how can she get into her tablet
Hi Mercedes, you will have to perform a factory reset to take the tablet back to when new!
Power the Tablet down completely. Press and hold the Power and Volume up buttons until a recovery screen appears. You should be presented with a screen that will allow you to perform a Wipe Data Factory Reset. Perform the reset then restart the Tablet.
3answers
TOO MANY PATTERN ATTEMPTS ON SAMSUNG GALAXY GT-P7100
Pattern Lock- Incorrectly enter pattern 5 times (4 or more points each time) . Pop up message will appear Click Next and you will be prompted for google a/c details or security question for pattern lock.
tap forgotten pattern and on next screen enter google account details. Then next screen allows you to choose a new screen lock option.
Otherwise for a factory reset use recovery mode
The only other solution is a hard reset which is only as a last resort. You need to access Androids Recovery mode. Check your manual. Most devices it is power off then power up holding volume + and power buttons.
Once in this mode use power down button to highlight "wipedata/factory reset option, then use power button to select it.
Vol - button to to scroll and select yes delete all user data option with power button. When device reset select option to reboot now and the device will turn on unlocked but you will have lost your personal data.
AX109JC20130709
You do not say what type of password was set and if you have forgotten it or just want to reset from a known password..
If you just want to change your gmail login password
- Go to google.com/accounts on the tablet browser
- Sign in
- "Change Password"
- Go back to the Home Screen on the tablet
- Open the GMail app, clicked on Menu, then Refresh -- you will get a sync error
- Wait for a notification to re-enter your password (a triangle with an exclamation point in the tablet notificaiton bar and/or something in the gmail screen)
- Enter the new password
This simple solution sometimes works:
Turn it off.
Turn back on.
When you get the warning triangle in the notification bar, open the notification.
You will then get a login screen.
Input your new password.
Pattern Lock- Incorrectly enter pattern 5 times (4 or more points each time) . Pop up message will appear Click Next and you will be prompted for goole a/c details or security for pattern lock.
tap forgotten pattern and on next screen enter goole account details. Then next screen allows you to choose a new screen lock option.
Locked with PIN or password _Try Screenlock bypass pro from play store.
Face unlock - you were asked to provide a pattern or PIN backup when you set it. Just bypass and enter PIN or pattern.
Good Luck
1helpful
HOW TO RESET A NEXT7P12 TABLET
Hi, you can try resetting by following the below steps. It works for most tablets.
1 turn off the tablet
2 press and hold the power button and keep tapping the volume down button at the same time.
3 it should take you to recovery screen. Go to factory reset by using volume button and select by using either the center button on the tablet or the power button if there is no center button.
please reply if it helped
Top Kocaso Tablets & eReaders Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
William McDowell
ADMIN Andrew
ADMIN Andrew
Are you a Kocaso Tablet and eReader Expert? Answer questions, earn points and help others
