Imei 353510020960549
SOURCE: Resetting Security Code
hi freinds
i have nokia 1100 phone ane my imei is 35793000/200543/4 and i had for got my security code can some one help me to reset it and can you help to reset code for nokia 1100 phone
SIM pin code:
This is a pin code that locks the sim card until you enter the correct code. This protects your account, even
if your sim is put into another handset. To reset it, you need the PUK code:
Pin Unlock Code (PUK)
If you miss key (or forget) your SIM pin code, and enter the wrong one 3-5 times in a row, the SIM will lock up, and you’ll need to enter the PUK unlock code to release it. You should ask your Network Service Provider for this code when you need it. Don’t try to guess it, because after a few wrong guesses, the SIM card will be permanently disabled.
Phone Security Code:
This locks the handset, as opposed to the sim card. You can also set some handsets to only accept a “new” sim if the phone security code is entered. To reset it, you need the Master code code:
Master Reset Code
Sometimes known as the Master Code, this allows you to unlock a handset if you have entered the Security Code wrongly too many times.
Which is the one that you want?
The default security code for Nokia is 12345
SOURCE: 5300 master reset code
this will need the attention of the nokia care persons at nokia show rooms.
only they can help you with this
as of mine losing security code a big problem the only solution for this, reformat the mobile to clear the old file.
