Panasonic Panafax UF-885 Plain Paper Laser Fax Logo
Posted on Jul 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Print error code 021 - Panasonic Panafax UF-885 Plain Paper Laser Fax
Anonymous
Level 3:
Master:
  • Master 377 Answers
  • Posted on Jul 07, 2009
Anonymous
Master
Level 3:
Master:
Answers
377
Questions
0
Helped
123717
Points
1027
1. The print job was too complex for available printer memory. 2. Press GO to resume printing.
3. If you lose some data, you might need to add more printer memory.
4. For a temporary solution, simplify the image or print at a lower resolution.
Anonymous
Level 3:
  • Master 527 Answers
Anonymous
Master
Level 3:
Answers
527
Questions
0
Helped
190583
Points
1378
Sir,
can u tell me the printer model name and no. it will find easily to solve your problem
Turboion croc classic flat iron bc-cr1. When I turn on, error code 021 and it shuts off. Is there a fix?
Error code 021 on a Turboion Croc Classic flat iron indicates a problem with the temperature sensor. This error can prevent the flat iron from heating up properly and may cause it to shut off unexpectedly.
To fix this issue, you can try the following steps:
  1. Turn off the flat iron and unplug it from the power outlet.
  2. Use a small screwdriver to open the back cover of the flat iron and locate the temperature sensor.
  3. Carefully inspect the temperature sensor for any signs of damage, such as bent or broken wires, loose connections, or burnt components.
  4. If you notice any damage to the temperature sensor, you will need to replace it with a new one. You can purchase a replacement temperature sensor from Turboion or from a third-party supplier.
  5. Once you have installed the new temperature sensor, reassemble the flat iron and plug it in. Turn it on and check if the error code 021 is still appearing.
  6. If the error code persists, you may need to contact Turboion customer support for further assistance. They will be able to provide you with more detailed troubleshooting steps and help you resolve the issue.
Dec 04, 2022 • Irons
Printing Error Info Code 021
It sounds like you had a power failure.
Press
function
7
monitor key slowly 4 times
asterisk key *
6
set
scroll down to SHIPMENT SET
set
fax machine should now reboot,
13helpful
3answers
Error code 021
Press
Function
7
monitor slowly 4 times
6
set
wait for the fax to initialize and come back to READY
5helpful
2answers
Printing error 021 of panasonic fax machine uf4100
Press
Function
7
* (asterisk key)
6
set
wait for machine to initialize
I have a panosonic uf-4000 fax it keep reading error 021. It is not listed in the book. What does this code mean
021 is a fuser error, that can either be reset in service mode or i may need a part in the fuser. Best to call a local service rep.
ERROR CODE #021
Try a new toner cartridge. If that doesn't take care of the problem, it's the fuser.
2answers
Panasonic uf885 error
Same here. I replaced the fuing unit but he error code 021 still is present.
Panafax UF-490 Fax
The fuser may be damaged or worn. A certified tech will need to replace it. Did you have a power outage? Ray
Top Panasonic Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
