Epson Stylus CX6600 All-In-One InkJet Printer Logo
Anonymous Posted on Dec 11, 2014
Power-up problem I have to hold down the power button for an increasing amount of time before the printer starts up. It's now more than 5 seconds. Any ideas?
4 Related Answers
Anonymous
  • 832 Answers
  • Posted on Feb 18, 2009
SOURCE: Had to shut printer down, now cannot restart
hello there!
thanks for using Fixya.com
Try to disconnect the power and again turn on/off the printer. Restart your pc or laptop as well. If still the same, you could uninstall and install again the software. Delete all the pending jobs.
Thanks!
websnail
Martin Smallridge
  • 419 Answers
  • Posted on Mar 26, 2009
SOURCE: epson rx560 general error
Unfortunately a "general error" is different from the commonly assumed "service required" error.
Usually a general error comes about because of something a bit more serious than a paper jam which stops the printhead from moving around as it should, cartridge chips not reading properly, etc...
It's worth trying the following and seeing if any of them help
  • Open the printer lid and using a flashlight/torch, carefully examine the area that the printhead travels along to see if there's any foreign objects, ink soiled paper, etc.. that might be getting in the way.
  • Try getting the printhead off the parking area and check this for any parts of the cleaning station that may have dislodged or other foreign objects that do not belong
  • Remove all the cartridges, clean the chip contacts carefully with a cotton bud and check the contact wires inside the cartridge holder area for any damage.
Beyond that it's a case of looking for clues that might indicate where the problem lies.. ie: if the printhead stops in a particular place, screeching noises, etc...
Hope some of that helps narrow it down some.
Anonymous
  • Posted on Apr 16, 2009
SOURCE: The printer will not turn on.
turn off printer then press and hold down three butons on the bottem of the small panle under the small screen on tne pinter,, hold the stop btn,,also the maintance btn and the on btn all at the same time,, hold for a few seconds and let go,,, be ready to it off strait away as it will make loud noise.. this will over ride the service message, and will work perfect,, i had the same problem,,
good luck
Anonymous
  • 83 Answers
  • Posted on Feb 16, 2010
SOURCE: R1800 printer turns on only when I hold the power
first, turn off the printer. unplug it from the power source. while its off, open the printer cover, so you could have an access to the inside of the printer, check for any obstruction, paper jam or any foreign object. if you found anything, take it out, if not, still turn on the printer after checking.dont forget to plug it in the power source, if the issue persists, call epson to get a replacement printer if the product is still 1 yr. from the date of purchase, if it is more than a year, most probably, thats out of warranty,
Top Epson Office Equipment & Supplies Experts
Rommel Balcita
Grand Canyon Tech
Grand Canyon Tech
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
