Televison & Video Logo
K
Kathy Anderson Posted on Nov 04, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I fix this?
I have a Sylvania hdtv flat screen, cl320s_1.5. When I turned it on it had a message, lost hdcp connection trying to reconnect. The tv has no sound.
Jay Brooks
Level 2:
New Friend:
  • Expert 42 Answers
  • Posted on Nov 04, 2014
Jay Brooks
Expert
Level 2:
New Friend:
Answers
42
Questions
0
Helped
11913
Points
117
This is a DRM error. The movie industry put copy protection into your tv. If you put a device that doesn't support it the copy protection it will disable features.. Solution take the tv back and get one without hdcp.
5 Related Answers
Anonymous
  • 11896 Answers
  • Posted on Jan 17, 2009
SOURCE: sylvania 42" flat screen won't turn on
First you should check the fuse and the wiring in your tv by removing the back cover. Make sure no wires are bare or touching. If there are any, wrap them with electrical tape.
If you cannot see anything wrong by looking, then it is probably the set has a bad transformer (high voltage)
Anonymous
  • Posted on Feb 17, 2009
SOURCE: PS3 (Pal) won't connect to Sylvania HD TV
I just figured it out last night - if you have used your playstation on an hd tv previously, it is set at the highest resolution possible - 1080p. You need to take it back to that tv, and go to display settings on your tv. If you select HDMI as they type of connection you'd like to make, it asks you what resolution your tv supports. In your tv instruction guide, it should give you this information. Check mark all of the resolutions your tv supports, making sure not to confuse 1080i and 1080p. After doing this you can take it back to your other television and it should work.
alxwein
  • 4 Answers
  • Posted on May 18, 2009
SOURCE: "Display connected non-HDCP compliant" error
The HDMI cable was causing "Display connected non-HDCP compliant" error message to appear.
When I reconnected my DVD to TV using regular cable with 3 color connectors(i don't know what is the proper name for that cable) that error message no longer appears on my screen and I was able to watch my movie normally.
Anonymous
  • Posted on Oct 19, 2009
SOURCE: replace fuse for flat screen 37 sylvania flat screen
i have a black cloudy area about 2 inches wide and 14 inches long at an angle onmy 37 ninch sylvania hdtv
Anonymous
  • Posted on Feb 25, 2010
SOURCE: Philips Flat Screen TV has sound but no picture
My Philips 50" Flat screen has sound but no picture. What should I do?
Top Televison & Video Experts
ADMIN Andrew
ADMIN Andrew
Larry
ADMIN Eric
ADMIN Eric
