Error code 4200 - Office Equipment & Supplies
Hp laserjet 4200 showing error code 53.10.03
You have to replace the formatter. These can be found on ebay used for around $30
How do i remove error 4200-0099296
As an error, the C-4200, refers to laser unit. Sometimes the main charge (mc) cause this error. Remove the mc and check the sound of the laser. If you don' t hear the laser sound, then the problem is the laser unit
Error code 218 is displayed on a forklift electric crown sc 4200 once we start it
you should checkout this website www.reliable-store.com that has books on all vehicles, name it they have it.
it covers wiring diagrams, electrical diagrams, fuse diagram, torque specs, PCV, error codes, fault codes, service info, repair info, parts info, owner's/service/repair/parts/maintenance manuals etc everything totally..
I have 1989 car model and I keep servicing and when needed repair it on my own. worth it !!!
Error 4200
Faulty laser unit. Or in very few cases a bad ground connection at the DV unit.
6helpful
2answers
Error code a 4200
c-4200? a c-4200 is a laser unit error. replace lsu.
2answers
Error code 4200
error code 4200 means some hardware problem open printer and clean some hardware if possible then turn on printer and check again
Scx 4200 lsu error
Hi computergala,
LSU error is is an error code for faulty LASER. Once isolated/replaced with new one, your unit will back to normal again. This is not DIY I would advice you to look for a professional to do the job for you because it is quite technical or send your unit to your local samsung service center.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
1helpful
How to overcome scanner error
Windows update kb840987 causes the problem.Removing that might fix the problem.
Or contact toll free no of samsung 1800110011 or
30308282 (prefix std code before this number).
3helpful
Error code 4200-002678 call for service
best case scenario... laser scanner harness or cable loose or bad... medium case scenario... laser scanner unit is bad... worst case scenario main board is bad...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
