Heating & Cooling Logo
Kevin Lidster Posted on Oct 19, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
On the error code list, I'm getting an error code of Open Rollout, How do you fix that?
New Ignition Plug, Cleaned the Flame sensor, New filter, Power is going to where it needs to go as far as I know,
  • 1 more comment
  • jabberwoky Oct 19, 2014
    disconnect the wires from the roll-out, with power off obviously, and check JUST the roll out for resistance... should read zero.
    reading voltage across the roll out means the circuit is OPEN and not conducting electricity
  • Kevin Lidster
    Kevin Lidster Oct 19, 2014
    right it reads 0.00 on both the sensor up against the back of the unit above the burners and the one behind the burners
jabberwoky
Level 3:
  • Master 739 Answers
  • Posted on Oct 19, 2014
jabberwoky
Master
Level 3:
Answers
739
Questions
0
Helped
234315
Points
3082
A 'roll-out' safety switch it a small button looking device with a smaller tab/button sticking out of it, near the gas injection manifold. has 2 wires attached. the reset button is generally between these wires. it's designed to shut the unit off, by breaking the power circuit, if flame ignition causes fire to back flash out of the fire box. Press the little button and try relighting. if the roll-out pops again, and there was no roll out of flame, you made need to replace it.
Testimonial: "the roll-out safety switch is still in place and has not popped out and has been tested with the volt meter and is testing good? what now"
  • Kevin Lidster
  • Kevin Lidster
    Add a Com"the roll-out safety switch is still in place and has not popped out and has been tested with the volt meter and is testing good? what now"ment
Top Goodman Heating & Cooling Experts
Paul Carew
jdthefixer
john h
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
