Computers & Internet Logo
I
Israel Ramirez Posted on Oct 19, 2014
My tripp lite smart1000lcd won't charge
The backup went to battery power and now it won't charge
Charlie F
Level 1:
New Friend:
  • Contributor 56 Answers
  • Posted on Dec 13, 2014
Charlie F
Contributor
Level 1:
New Friend:
Answers
56
Questions
0
Helped
18414
Points
95
Mine too. pull both batteries out and check the voltage on each.
One may be unusable as was mine. Peel of the Tripplite label to determine what size it is to get a comparable and much cheaper one.
5 Related Answers
A
Anonymous
  • Posted on Dec 27, 2007
SOURCE: tripp lite internet office 500
Quit out the screw in the back of the equipment, QUit out the battery power supply under the device.
Greetings
Anonymous
  • 871 Answers
  • Posted on Feb 07, 2008
SOURCE: replacing batteries on a Tripp Lite Smart 2200
hi there
tripp lite includes battery replacements and they have authorized sellers and distributors. however, they dont sell directly to consumers like us. they do have sales and support if you want someone from them to have the battery replacements installed
call there Customer Support (773) 869-1234
or visit there online site for more details.
http://tripplite.com/index.cfm?countryid=122
hope this helps.
240cpa
  • 548 Answers
  • Posted on Jan 05, 2009
SOURCE: No Power when turn on so battery wont charge
Try leaving it off, but plugged into the wall outlet so the batteries can charge up. If they are new, they are probably without a charge. The instructions should indicate how long it needs to charge - probably most of the day.
Anonymous
  • 105 Answers
  • Posted on Jul 26, 2010
SOURCE: Only one side of the outlets work...
From the User Manual:
“OVERLOAD/CHECK BATTERY” LED: this red LED lights continuously after a self-test to
indicate the capacity of the battery-supported outlets has been exceeded. To clear the overload, unplug some of your equipment from the battery-supported outlets; then use the ON/OFF/TEST button to run a Self-Test. If the UPS continues to detect an overload, remove more equipment and repeat the self test until successful.
CAUTION! Any overload that is not corrected by the user immediately following a self-test may cause the UPS to shut down and cease supplying output power in the event of a blackout or brownout.
The LED flashes to indicate the battery needs to be recharged or replaced. If the LED flashes (and a continuous alarm sounds) during a prolonged blackout or brownout, the UPS’s batteries are nearly out of power; you should save files and shut down your equipment immediately.
If the LED flashes following a UPS self-test (after the UPS is turned ON), it may indicate that the battery needs to be replaced. Allow the UPS to recharge continuously for 12 hours; then use the ON/OFF/TEST button to run a Self Test.
If the LED continues to flash, contact Tripp Lite for service. Should your UPS require battery replacement, visit Tripp Lite on the web at www.tripplite.com/support/battery/index.cfm to locate the specific replacement battery for your UPS.
Hope this helps!
Anonymous
  • 3 Answers
  • Posted on Oct 19, 2010
SOURCE: Tripp Lite OMNI 1000 LCD will not stay on
Turn UPS on: Press and hold the ON/OFF button for one second.
Run a Self-Test: Press and hold the MUTE/TEST button for two seconds (until alarm beeps several times).
The test will last 10 seconds. All LCD Display icons will be illuminated and the alarm will sound.
If the fault icon remains lit, the battery-supplied outlets are overloaded. Unplug powered devices until you remove the overload.
If the "Replace" icon remains lit and alarm continues to sound, the UPS batteries need to be recharged or replaced. Allow UPS to charge for 24 hours and repeat self-test.
Top Tripp Lite Computers & Internet Experts
Steve Pack
Steve Pack
Gruber Power...
Gruber Power...
Are you a Tripp Lite Computer and Internet Expert? Answer questions, earn points and help others
