Televison & Video Logo
A
Anonymous Posted on Oct 18, 2014
Need to know the remote code to program a dish remote for a vizo tv
I,m trying to get my remote to work for dish with a viso tv
Level 3:
Top Expert:
  • Televison & ... Master 76,851 Answers
  • Posted on Oct 19, 2014
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15380470
Points
237768
0281,0288,0275. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
5 Related Answers
Anonymous
  • 51 Answers
  • Posted on Aug 29, 2008
SOURCE: my one for all won't program...
dish network remotes are universal, you can program your receiver, vcr/dvd, telivision and stereo to most remotes. if you need info on this just post again, otherwise i would list your issue under the remote brand
Anonymous
  • 64 Answers
  • Posted on Nov 25, 2008
SOURCE: dish network remote with a element tv
Since you dont have a popular brand set you should try using the scan method. Here is a link with a video to help program your dishnetwork remote to work with your set. http://www.disheez.com/videos/dish-network-video/programming-dish-network-remote/
Anonymous
  • 374 Answers
  • Posted on Apr 13, 2009
SOURCE: My dish network remote isnt working with my LG tv
Not all TVs are supported by our remotes. You can do a power scan to see if you can find one that works or you can get the newest remote type that supports a large array of TVs. The new rmote is a model 21 which will work in IR and UHF mode. To perform a power scan do the following: Press and hold the upper left TV button on the remote until all lights on top light up and release.Now press the small red TV button and release - the upper tv button should be lit solid. Now press the arrow up key slowly until set turns off. Once it does presss the arrow down key once and then the arrow up key and the TV should power on. Now press the pound sign and the rrecord button. Now press the upper SAT button and release . You should be able to control the set now. Thanks for using Fix Ya.
Anonymous
  • 374 Answers
  • Posted on May 25, 2009
SOURCE: need Sanyo TV code numbers
These are the codes for Sanyo TV'S for this remote. The newer TV codes are at the end so work in reverse order when inputting these codes. Thanks for using Fix Ya.
542, 589, 590, 591, 592, 609
Anonymous
  • Posted on Jul 15, 2009
SOURCE: Cannot program Dish Universal Remote for Emerson TV
This worked for me. I had to scan down quite a few times but eventually my tv turned off and I set the code with the # button. It may work for you too and save you some money on a UR.
http://www.satellite-tv-planet.com/DishNetworkRemoteControlProgramming.htm
Scan For Device Codes If the code for the device you are programming is not listed in the user manual or on this site, try these steps to scan the remote controls memory for device codes.
1) Turn the power on the device on
2) Select and hold the mode button for which you are programming, such as the TV button, on the remote until you see all the lights of the mode buttons flash. Once you let go, that mode button that you chose should now be blinking. When using the Aux mode button only use the number pad to enter 0 for a second TV, 1 for a second VCR/DVD, 2 for a amplifier, tuner, or cable box. Then press the STAR (*) button.
3) Press the power button on the Dish Network remote control.
4) Repeatedly press the UP or DOWN button on the remote to scan for the correct code (do this slowly so you do not skip over the right code for your device). When the correct code is reached the device will turn off.
5) Press the POUND (#) button to store the code in the Dish Network remote.
6) Press the power button to turn the device back on and try using other buttons on the remote to make sure that they also work. Sometimes the power button will work while others may not.
Top Televison & Video Experts
ADMIN Andrew
ADMIN Andrew
Larry
ADMIN Eric
ADMIN Eric
