If you mean that you need the frequencies and system information for your local services you can find lots of good information a http://www.radioreference.com.
The programming is not done on the bar code scanner, but on your alpha unit. You need to program the item price when you program the item UPC and the Description.
from manufacturers site take scan code sheet, you will just find there programming scan codes, one for start programming, another to terminate auto entry and third to terminate programming. that is correct procedure if scannig is automatically set in scanner, if scanning is in your database on other hand, you need to re-write that bit which insert your code to database/spreedsheet automatically and change it to manual, as i do not know which of these method you use, i cannot be more specific.
try scanner first! usually scanner is programmed on automatic.
There should have been a sheet or book of bar codes that came with your scanner. These codes will allow you to program your scanner to do most anything, including adding a tab. You simply look at the bar codes and read what they do. you simply scan the one that adds a tab and it will forever add the tab unless you re program it.
If you have lost your book/bar code page, you should be able to go to the manufacturer website and download/print a document with the programmable bar codes.
Programming the 248 is fairly simple once you know the steps. - Turn the scanner ON - Press the MANUAL key to stop scanning - Enter the channel number that you wish to program (01, 02, etc.) - Press MANUAL - Enter your frequency, including the decimal point (e.g. 156.055) - Press E to confirm - Press MANUAL to advance to the next channel
Need the manual for your scanner? You can download/print it here:
http://www.uniden.com/pdf/BC248CLTom.pdf
For a comprehensive database of active frequencies in your area, viksit:
