Canon PowerShot A420 Digital Camera Logo
A
Anonymous Posted on Oct 05, 2014
Will not set date and time
When i start the camera with the OnOff it asks me to set date and time
Jerry Kramer
Level 3:
  • Canon Master 3,933 Answers
  • Posted on Oct 05, 2014
Jerry Kramer
Canon Master
Level 3:
Answers
3933
Questions
Helped
906220
Points
12076
You just simply need to set the time and date and you will be set to go and not see this come up again. It can be done in the setup menu on your camera.
5 Related Answers
old marine
old marine
  • 2426 Answers
  • Posted on Jul 26, 2008
SOURCE: date and time settings
The date battery needs to be replaced. It is a coin-type battery, CR1220. It fits in a holder that slides out from the bottom of the camera, opposite the side from the battery cover for the regular batteries. When putting the new battery in the holder, the negative side of the battery should be visible. Illustrated instructions are on page 87 of the Advanced User Guide.
KingDWS
Dave King
  • 1606 Answers
  • Posted on Sep 12, 2009
SOURCE: everytime I turn the camera on the time and date
There are two batteries in the camera. One is the big one you charge and the other is a little coin type battery. This coin battery maintains your settings and when it goes your camera forgets things. Same setup on computers and a lot of other electronics. In your camera the battery is a CR1220 worth about $1-$2. It should last about 3-5 years but you never know.
The battery is in a little holder on the left hand side of the camera. Its under the same cover as the usb connector and power plug in. You should be able to pop out the battery holder fairly easily. This is one of those things that if you take the camera to a battery store they will probably do it for you if they aren't busy. If you look at page 137 of your manual you will find the instructions for doing it yourself.
Anonymous
  • 11967 Answers
  • Posted on Feb 25, 2010
SOURCE: camera Canon A710 IS started to ask set time date when turned on
When the camera is left without power for an extended period of time, the time and date settings are gone. You need to reset them and when you're finished, click the set/ok button twice.
Kiran Anto
  • 420 Answers
  • Posted on Sep 11, 2010
SOURCE: my canon powershot camera goes to set the date and
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
t00nz
CameraR
  • 4738 Answers
  • Posted on Dec 30, 2010
SOURCE: Every time I switch on
The camera's clock battery has worn out. Unfortunately, on most Canon SD series, this battery is not user serviceable. Recommend contacting Canon to see if they'll replace it, hopefully at a reasonable cost. 1-800-OK-CANON
Top Canon Cameras Experts
Grand Canyon Tech
Grand Canyon Tech
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Canon Camera Expert? Answer questions, earn points and help others
