Could someone tell me what this code means?
Dear Anon,
Could be, P1110 is Charge Air Bypass Problems. I would check all the pipework (small bore vac pipes) to and from the dump valve, plus if you have one of those plastic bosch valves it might be time to change it. If you trace the small bore tube from the dump valve back to the bulkhead. Remove the tube, clean the end of it then suck/blow (i can't remember which one), if you can suck/blow the diaphragm has gone in the dump valve and it needs replacing. As Chris already said, check all the vacuum tubing as well for splits/tears and whether they are actually attached. Thanksto Kermit/Chris9-5
