Garden Logo
A
Anonymous Posted on Aug 30, 2014
I cant pull the string to start the mower
At first it seemed like the wheels were uneven, I adjusted them and started the mower then the blade was coming loose while I was mowing and it cut off. I tightened the blade and then tried to restart the mower and the string seems stuck.
charles beach
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Master 1,917 Answers
  • Posted on Sep 02, 2014
charles beach
Master
Level 3:
Renaissance:
Answers
1917
Questions
Helped
581269
Points
3010
Pull plug out tie up bail handle see if you can turn engine over by hand if you can pull hard on rope it has jamed if not .move check for locked up mover add oil to cylinder for it to turn over till its free my have to take recoil off to do this if the reciol starter pawls or lock in
5 Related Answers
Anonymous
  • 448 Answers
  • Posted on Jan 10, 2009
SOURCE: mower will not start. starter is stuck.
Is this solved?
Anonymous
  • 109 Answers
  • Posted on Apr 16, 2009
SOURCE: Mower hit a big rock and stoped running
If you hit something hard enough to partially shear the key on the blade adapter, you did shear the key on the flywheel, and it will need to be replaced for the engine to run properly.
Anonymous
  • Posted on May 24, 2009
SOURCE: Pull rope seems to be locked up...won't pull
make sure you can turn the blade by hand, make sure grass isn't stopping the blade after that make sure the break cable isn't bad, sometime's the cable don't disengage the break from the flywheel. Hope this works.
Anonymous
  • 183 Answers
  • Posted on Sep 05, 2010
SOURCE: I have a briggs and stratton quicksilver, just got
Not to worry. When you tipped the mower on its side, oil ran into the exhaust. Allow the engine to run few minutes and it will stop smoking. The B&S engine will put oil in the muffler if tipped to the left, and oil into the carburetor if tipped on the right. The only safe way to tip the engine is where the spark plug is pointed upward.
Don't forget to check your oil level and adjust as necessary.
Testimonial: "i will try what you suggested, i did tip it on the side you described, but thought engine had gone... it still runs so you must be right thankyou"
Anonymous
  • 144 Answers
  • Posted on Jan 02, 2011
SOURCE: mower is making a clunking
I think that noise is because your blades are loose. They should be tightened right away because they could come off when you are using it with the possibility of injury to somebody. I have serviced some mowers with that problem. They make more noise when starting because they are turning slow and moving around more than when turning at high speed. Best regards and good luck.
Top Garden Experts
ADMIN Andrew
ADMIN Andrew
john h
CJ Rock
CJ Rock
