Computers & Internet Logo
A
Anonymous Posted on Aug 27, 2014
Attachmate software What TCP / UDP ports need to be open
Jim Pattison
Level 3:
Master:
  • Master 1,004 Answers
  • Posted on Aug 29, 2014
Jim Pattison
Master
Level 3:
Master:
Answers
1004
Questions
0
Helped
282032
Points
1705
The manual will generally tell you. Telnet ports need to be open, but you willcneed to knowxif you are conecting to 5250, 3270 or vt100 and see if other ports need to be opened up.
5 Related Answers
Anonymous
  • 2961 Answers
  • Posted on Sep 11, 2007
SOURCE: this is samer
go to the link below and the site will forward them for you http://www.portforward.com/english/routers/port_forwarding/Encore/ENDSL-AR4/ENDSL-AR4index.htm
Anonymous
  • 67 Answers
  • Posted on Mar 31, 2009
SOURCE: how do i open my ports?
Login to the routers web interface, go to the port forwarding page and insert the information required
Anonymous
  • 854 Answers
  • Posted on Jul 23, 2009
SOURCE: i want to define tcp port for another program
Port Forwarding
A. Determining the IP Address and MAC Address of a Computer:
Note: Please use the computer for which the Ports are to be opened:
For Windows 2000/XP users:
1. Please click on Start and select Run.
2. Type in cmd and click on OK.
3. In the Command Prompt, please type ipconfig/all then press Enter or Return key.
4. Please make sure that the Ethernet adapter has an IP Address that is the same range as the router (e.g. 192.168.1.2 for the computer and 192.168.1.1 for the router).
5. Please note down the IP address and Physical address.
B. Reserving an IP Address:
1. Please open any web browser like Internet Explorer or Netscape Navigator.
2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
3. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
4. When the setup page opens, click on LAN IP Setup under Advanced tab.
5. Click on Add under Address Reservation.
6. Under Address Reservation window, please select the radio button of the computer you wish to add from the Address Reservation Table.
7. If the computer you want is not on the list, please click on the Refresh button to update the table.
8. If the computer is still not on the Address Reservation Table, please type in the IP Address, MAC Address (Physical Address), and Device Name of the computer you wish to add.
9. Click the Add button when done.
C. Opening Pre-Defined Ports for Internet Services:
1. Click on the option with the name Port Forwarding/Port Triggering under the Advanced menu.
2. Please select the service type Port Forwarding. The router pre-defined services are listed there.
3. From the Service Name pull down list, select the service that needs to be hosted.
4. Enter the IP address of the computer in the Server IP Address box.
5. Click the Add or Apply button.
6. Repeat all steps to open more ports.
Note: If the name of the Internet service does not appear in the drop down list, you may manually open the ports for that Internet service. Please follow the steps below:
D. Opening Ports for Games, Applications or Custom Ports:
1. Click on Add Custom Service button.
2. Type the service name in the Service Name box and the lower range numbers in the Starting Port box.
3. If the application uses only a single port; type in the same port number in the Ending Port box.
4. If the application uses a range of ports; type in the higher range numbers in the Ending Port box.
5. Type the IP address of the computer in the Server IP Address box. Click Apply button.
6. It will then refresh to the Port Forwarding page, and will show the list of all ports opened in tabulation.
7. Repeat all steps to add more ports for more services.
E. To Edit or Delete a Service Entry:
1. Click on the Radio Button that needs to be Edited /Deleted, under the Port Forwarding page.
2. Modify the information from the Service Name, Starting Port, Ending Port, and the Server IP Address, and then click the Apply button.
Silverdragon
electronic & computer repair& servicre
  • 12061 Answers
  • Posted on Feb 15, 2010
SOURCE: HOW CAN I OPEN A PORT TCP AND UDP IN FRENCH FOR DSLG604T V3.00
Exemple : Vous accueillez un web server sur un PC qui a l'IP address de LAN de 192.168.0.50 et votre ISP bloque le port 80. Nommez le Virtual Server (par exemple : Web server) écrivez l'IP address de la machine sur votre LAN (par exemple : 192.168.0.50 Entrez dans le port privé comme [80] Entrez dans le port public comme [8888] Choisissez le protocole (par exemple TCP). Assurez que le programme est placé à toujours Cliquez sur sauf pour ajouter les arrangements à la liste virtuelle de serveurs Répétez ces étapes pour chaque règle de Virtual Server que vous souhaitez s'ajouter. Après que la liste soit complète, clic sauf des arrangements au dessus de la page. Avec cette entrée de Virtual Server, tout le trafic sur Internet sur le port 8888 sera réorienté à votre web server interne sur le port 80 à l'IP address 192.168.0.50.
My French isn't good sorry.
Testimonial: "your french is very good for me.Now I try the solution and a big thanks you"
Anonymous
  • 50 Answers
  • Posted on Mar 15, 2010
SOURCE: PlayStation 3 keep getting nat type 3 when need type 2
Hi
I was having problems with my PS3 as well I did the following
updated firmwire
Also I assign static ip address on my PS3 and forward ports used by PS3 to static IP address of PS3 on routers firewall.
Ports used by PS3:
udp 3478
udp 3479
udp 3658
tcp.domain (port 53)
udp.domain (port 53)
tcp.http (port 80)
tcp.https (port 443)
udp.ssdp (port 1900)
tcp.amandaBackupInitiation (10080)
tcp.Jabber SSL/TLS (port 5223)
tcp.10075
tcp.10078
tcp.10079
If your still getting problems configure the PS3 to be in your DMZ.
DMZ will be under applications and gaming. Just look for that setting in your routers setup page and add your PS3 IP address to it.
XBOX ONE CANNOT CONNECT TO THE INTERNET THROUGH WIRELESS ROUTER
my first guess would be you need to open ports in your firewall.
  • port 88 (udp)
  • port 3074 (udp and tcp)
  • port 53 (udp and tcp)
  • port 80 (tcp)
  • port 500 (udp)
  • port 3544 (udp)
  • port 4500 (udp)
Needs nat type open
XBOX
You Will Have to Disable the Firewall In Your modem / Router
And IF it is a router then Open The Ports
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
And Also Make sure that UPnP is Enabled
PS3
You will have to open the following ports in your modem /router
Make sure the firewall is disabled in the Modem /Router
Playstation Network Required Ports
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Playstation Online Game Ports
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
You can use http://whatsmyip.org/ports/ to test if the ports are open.
Regards
Tom
My nat is strict
XBOX
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
PS3
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
Regards
TOM
How do i change the NAT type to open
XBOX
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
PS3
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
regards
Tom
The NAT is on 3 and it needs to be 2 for the PS3 to work online properly. i have a Zyxel_41C.
PS3
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
Regards
Tom
How do i change NAt type to a lower type
XBOX
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
PS3
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
Want to set nat type to open
XBOX
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
PS3
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
1helpful
2answers
Can I change the Nat type? Can't figure out how to change it from type 3?
XBOX
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
PS3
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
I need help changing my nat settings from strict to open for my ps3, i have a bt home hub router, and my upnp is enabled, is there anything else i can do???
PS3
You will have to open the following ports in your BT router
Make sure the firewall is disabled in the Router
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
Hi
updated firmwire
Ports used by PS3:
udp 3478
udp 3479
udp 3658
tcp.http (port 80)
tcp.10075
tcp.10078
tcp.10079
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
